Results 1 to 5 of 5
Thread: DTC COdes Definiton
    May 2012
    DTC COdes Definiton
    I am just the begineer in Diagonostic .
    I am looking for DTC code definition for emission and non-emission related DTC's. What are all other standards available for defining DTC codes?
    EX : Pxxxx , Bxxxx , Cxxxx and Uxxxx - this i am little bit aware of .Is there any other way to define DTC code?
    Oct 2008
    Sure, buy SAE j2012 and you get the defined P- and U-codes. See: http://standards.sae.org/j2012_200712/
    As an alternative you can checkout this website: http://www.dtcsearch.com/
    It will take some time, but a lot of codes (including manufacturer specific) can be found there. Just click on P0 to start with.
    P0-codes: 2897, P2-codes: 1182, U0-codes: 534. Grand total more than 4600 codes. And that are just the defined ones.
    May 2012
    Quote Originally Posted by p2psmurf View Post
    So to define DTC , only this way is possible worldwide irrespective of the OEM.
    Or any other way is also DTC codes can be define.
    Hope you understood my query.
    Rounak
    Oct 2008
    If you mean codes from the pre-obd2 era, then one way is to search the internet (but the info is very limited).
    The only sure way is to buy a factory tester, let's say Tech-1 from Opel (if that is still available) and reverse engineer everything.
    The same applies to codes from other systems than the power-train (Abs, Airbag, Airco, etc.) for newer cars. Buy the tester and reverse engineer.
    Maybe if you join the Society of Engineers in the USA you can get some codes. But that's a hefty fee each year.
    Now as to "worldwide", there's a nice goal. Do you want to make this your life-time occupation?
    And would this include the VW Gol (No, I didn't forget the F) from Brazil with a Ford engine that runs on ethanol?
    And would this also include the Opel Astra from India that uses a (locally made) Defita engine system, which is only used in India?
    I think you may have to limit yourself to a specific area, and not all makes.
    Newbie alexjohn517's Avatar
    Jun 2012
    CA LA
    Quote Originally Posted by rounak View Post
    P0001-P0099 - Fuel and Air Metering and Auxiliary Emission Controls
    P0100-P0199 - Fuel and Air Metering
    P0200-P0299 - Fuel and Air Metering (Injector Circuit)
    P0300-P0399 - Ignition System or Misfire
    P0400-P0499 - Auxiliary Emissions Controls
    P0500-P0599 - Vehicle Speed Controls and Idle Control System
    P0600-P0699 - Computer Output Circuit
    P0700-P0899 - Transmission
  1. LED codes for M4
    By Cham in forum M4-ATX
    Last Post: 07-04-2011, 01:24 AM
  2. LCD Remote Codes
    By tim123 in forum LCD/Display
    Last Post: 10-27-2009, 09:41 PM
  3. Codes?
    By avz in forum Car Audio
    Last Post: 03-04-2009, 10:00 AM
  4. OBD-Codes.com
    By Swanny in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-09-2009, 04:34 AM
  5. need codes for obd11
    By firehawk1 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-23-2007, 12:06 PM
