What pc or phone based scanners can read the GM body control module (airbag codes)
Im in the market for a new scanner and the ones over at http://www.scantool.net will read the airbag code if you buy the extra software excpet I dont really like that you cant use the same module for android as iphone. I would think that since they use bluetooth or wifi either platform would be able to connect to it. Anyway I was just wondering what other models may be able to read my airbag code. Im also trying to find one that will read injector rates but that feature is not as important as the airbag
thanks
