Hello everybody,
I want to know how can I programe the PIC18F2480 to use it as a ELM237?
can you tell me where I can find it's program or how can I write it?
thank you so much.
Printable View
Hello everybody,
thank you so much.
Hi! and welcome to the forum! This topic is in the wrong place, so it will be moved to the OBD2 subforum.
Why would you want to do that? There are a good many years of engineering that go into the programming of the ELM327 and related chips. Your best bet if you want a microcontroller solution is to either buy one of these: http://www.scantool.net/dev-tools/stn11xx/stn1110.html (ELM327 compatible, but WAY more features, and much higher quality), or buy one of these: http://www.scantool.net/dev-tools/mo...roobd-200.html Which handles all the extra hardware required to connect to OBD2 signaling.
What are you trying to do? Perhaps if you gave us an idea what your end goal was, we could better assist you?
