Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
Thread: Hacking the Can Bus
  1. #41
    May 2012
    Grandville, MI
    Ok thanks. I have a 2003 Chevy Avalanche so I am not sure if this will work for me directly but it is worth mentioning if you are going through the trouble of trying to build something when you can buy an already working setup that doesn't require any additional hardware.
    This board is less than $200 and may be the fastest ARM dev board out there with quad 1ghz cores and up to 4 video outputs. 1 Gig of ram onboard and can use LAN, Sata or MicroSD out of the box to boot from. I will likely get cheap SATA drives to boot from since I believe those are more likely to work without issue than MicroSD cards over the long haul and would be much faster.
  2. #42
    May 2014
    Hello, I made the can-shield using this scheme http://lnxpps.de/rpie/. I use it for hack my Skoda Octavia A5 2011 year.
    Attachment 71760
    To communicate with canbus I use can-utils.
    All perfectly work, I can control my windows with commands such as:
    cansend can0 181#0200 // Open driver window
    cansend can0 181#0800 // Close driver window
    For iPad I wrote a app that displays a data in real time for devices in the individual cells:
    Attachment 71759
    Using this app, I found some can-devices:
    181 - Control/Read status of Windows
    381 - Read status of front left Door (open/close)
    470 - Read status of front right Door (open/close)
    291 - Read status of back right&left Doors (open/close)
    531 - Control/Read status of Lights&Winking
    5D1 - Read status of Windshield
    591 - Read status of CentralLock
    Many IDs I can't define, If someone can help with finding IDs, I'll be glad!
    I want to found a speed, rpm, distance and other IDs.
  3. #43
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    Sorry to revive this thread. I'm surprised.
    Has anyone found IDs for GM (03 Cadillac specifically for me) regarding simple driver information messages? 'Door ajar', 'Trunk open', 'Low fuel', 'Ice possible', etc.
    Is there any place (site/link) that shares IDs found?
    Thanks.
    John
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  4. #44
    Nov 2012
    Quote Originally Posted by jmullan99 View Post
    Thanks.
    John
    "P" codes are listed here:http://www.engine-light-help.com/gm-trouble-codes.html
    If you want the actual LAN data, you are going to have to "sniff" it out.
  5. #45
    Apr 2015
    hi,
    i'm trying to understand if I can connect my Arduino to the OBD port of my VW Golf to control the steering wheel buttons, but I did not understand very well if it is possible to do that.
    Can anyone help me?
  6. #46
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by gabriele83 View Post
    hi,
    Can anyone help me?
    I think you must to use a CAN bus between arduino and your OBD interface ! No ?
  1. hacking a printer's LCD
    By natedawgg in forum LCD/Display
    Last Post: 03-19-2009, 03:48 PM
  2. Hacking Iguidance
    By Peoples in forum GPS
    Last Post: 08-28-2005, 07:40 PM
  3. Hacking Irman
    By Cheekz185 in forum Input Devices
    Last Post: 07-13-2005, 01:18 PM
  4. no TS, no hacking, which to buy?
    By DaddyZ in forum LCD/Display
    Last Post: 12-09-2004, 11:55 AM
  5. Frodo: 1.0.9 Hacking.
    By hevnsnt in forum FrodoPlayer
    Last Post: 10-17-2004, 06:54 PM
