Results 1 to 2 of 2
Thread: Need help on 2007 Nissan 14230-4
    May 2013
    Unhappy Need help on 2007 Nissan 14230-4
    Hello,
    I have a Nissan Tiida 2007 and im trying to make a hobby project with OBD2. I tried many apps for any OS and no one can communicate with it. I tried serial terminal too and the response was always BUS ERROR/NO DATA.
    So i found some dumps from unknown app which i tested on my car and they work but i dont know how to interpred them:
    Code:
    REQUEST:  ATZ
    RESPONSE:  ATZ
    RESPONSE:
    RESPONSE:  ELM327 v1.5>
    REQUEST:  ATSP5
    RESPONSE:  ATSP5OK>
    REQUEST:  ATE0
    RESPONSE:  ATE0OK>
    REQUEST:  ATS0
    RESPONSE:  OK>
    REQUEST:  ATH1
    RESPONSE:  OK>
    REQUEST:  ATAT1
    RESPONSE:  OK>
    REQUEST:  ATST3A
    RESPONSE:  OK>
    REQUEST:  ATAL
    RESPONSE:  OK>
    REQUEST:  ATSH8110FC
    RESPONSE:  OK>
    REQUEST:  ATWM8110FC81
    RESPONSE:  OK>
    REQUEST:  3F
    RESPONSE:  BUS INIT: ERROR>
    REQUEST:  3F
    RESPONSE:  BUS INIT: OK
    RESPONSE:  83FC107F3F115E
    RESPONSE:  >
    REQUEST:  2211000401
    RESPONSE:  87FC10621100E4010001EC
    RESPONSE:  >
    REQUEST:  2211200401
    RESPONSE:  87FC10621120000C09114C
    RESPONSE:  >
    REQUEST:  1A81
    RESPONSE:  87FC105A3145553430415D
    RESPONSE:  >
    REQUEST:  3E
    RESPONSE:  81FC107E0B
    RESPONSE:  >
    REQUEST:  3106FFFF
    RESPONSE:  82FC10710605
    RESPONSE:  >
    REQUEST:  3206
    RESPONSE:  83FC107F3278B8
    RESPONSE:
    RESPONSE:  >
    So my understanding is that he uses physical addressing but i am not sure how the pids are encoded in it. Also, the ECU gives BUS ERROR until it receives 3F which i dont know what it means? And why are there some commands without prefix "22": 3206, 3106FFFF, 3E?
    Some identified commands here:
    The following command corresponds to "injector fuel"
    request: 2212060401, ex. responses: 85FC1062120600EBF6, 85FC1062120600E7F2
    The following command corresponds to "Base fuel schedule"
    req: 2212080401, ex. responses: 85FC106212080FCCE8, 85FC106212080FE804
    The following command corresponds to RPM (im not 100% sure about this):
    req: 2212010401, ex. response: 85FC10621201003D43
    Command for Speed: 2211020401, response where the first char is missing: %4FC1062110200 (this is at 0km/h)
    I tested all of the above on the car and they work. ECU gives BUS ERROR on pid 0100 and only gives "BUS INIT: OK" after few "3F" commands.
    Please give me any direction.
    Thanks!
    Feb 2014
    Re: Nissan
    Hi, Have you made it work?
    Have you tried the torque custom init string for nissan?
  1. 2007 Nissan 350Z
    By Zynester in forum Show off your project
    Last Post: 04-09-2008, 10:23 PM
  2. 2007 Nissan Altima 2.5S
    By macmini in forum Worklogs
    Last Post: 03-29-2008, 11:37 AM
  3. 2007 Nissan Pathfinder Amp install Questions
    By Signalcc in forum Newbie
    Last Post: 02-08-2008, 04:12 AM
  4. 2007 Nissan Maxima
    By ladams02 in forum Worklogs
    Last Post: 02-04-2008, 12:34 AM
  5. 2007 Nissan Sentra H.U.D
    By edgofrea1ity in forum General Hardware Discussion
    Last Post: 07-09-2007, 06:13 PM
