Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 1991 car with no obd2 port. i want a carpc as guages. how?
  1. #11
    May 2012
    Grandville, MI
    You need to be able to read the sensors one way or another. In come cases you can get sensors that have both the original analog output and a digital compatible signal or you have to tie into the original sensor. It can be a pain in the butt if you don't know much about building electronics. Either the phidgets or arduino should work. Both will require programming to make them work. If you knew electronics and how to program this would be a simple weekend project. Not knowing... Could be a 2-6 month project depending on how much you need to learn to do it.
  2. #12
    949
    949 is offline
    Mar 2010
    i just found out what to get!
    very excited about it.
    i found out that PLX devices will do what i need and with less hastle. the modules will link up to a cpu via USB connection. the modules will link up to the sensors. so it will be the go between.
  3. #13
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    WOW that's gonna be expensive to do that using plxdevice's, 100 bucks just for egt sensor and it looks like as much hassle to install as gauge sensor, but at 3 times the price. And no front-end support. SNO
  4. #14
    Raw Wave
    Nov 2009
    I was even thinking that with earlier suggestions... I was thinking PICs etc.
  5. #15
    May 2012
    Grandville, MI
    For someone with no programming knowledge and no electrical knowledge it might make sense to use something pre packaged. Although I am thinking someone could help out on how to get sensors working with an Arduino development board or other setup. And Arduino has much information out there. And some front ends are starting to show some support for such things.
    Or maybe even get a new engine management system that uses its own sensors. One that can be interfaced into by your PC. They ARE out there although they normally use proprietary hardware and would be impossible to provide front end support for.
    Rodney
  1. Fusion Brain CarPC LT1 dash gauges project
    By ACCLR8N in forum Fusion Brain
    Last Post: 02-14-2014, 09:01 AM
  2. non-OBD2 gauges
    By nuk1ear in forum Newbie
    Last Post: 08-24-2011, 06:59 PM
  3. obd2 port (crv 02)
    By carpman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-23-2011, 03:14 PM
  4. Custom gauges for engine management software, non-OBD2
    By ddogg_777 in forum Software & Software Development
    Last Post: 02-17-2010, 03:27 PM
  5. Finding OBD2 Port on Nissan 200SX
    By ShawJohn in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2005, 05:11 AM
