Results 1 to 3 of 3
Thread: obd2 help
    Nov 2013
    obd2 help
    Hello:
    I'm new here so if this the wrong place for this ?, please let me know.
    I'm working on a program for a obd2 "elm327"
    and need some help:
    Well I made some head way:
    With the one request: 01 05
    I can get the info I need, I know the byte(s) for the pid,data etc., but I need to use the "ATMA"
    and I'm a little lost:
    Settings= at L1,at H1,at S1,at AL,at SP0
    With the "at ma"
    I get:
    8A EA 29 20 A7 00 30
    AA EB 60 20 A7 00 E7
    E8 FF 10 03 B3
    88 25 29 07 00 97
    68 49 10 10 56 90
    E8 FF 60 03 98
    88 3B 10 43 80 0D
    48 FF 40 06 03 AC
    8A EA 40 A0 9E 50 26
    AA EB 60 A0 9E 50 2E
    8A EA 10 A0 8C 00 65
    8A EA 10 20 8C 00 A5
    88 53 10 04 C4
    4A EA 40 20 91 00 6B
    48 FF 40 06 03 AC
    What I need to do is find out which byte(s) is the pid, data etc.
    I have been looking at the " en.wikipedia.org/wiki/OBD-II_PIDs‎"
    Can't make heads or tails :-(
    Can you please HELP ?
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Welcome to the forum! You placed your question in the right spot. I really can't offer too much help but maybe try this link http://obdcon.sourceforge.net/2010/06/obd-ii-pids/ There are a few good knowledgeable peeps here just might take some time to get a response as the forum is a little slow these days. Good luck SNO
    Jan 2014
    Quote Originally Posted by SoyEli View Post
    Hello:
    and need some help:
    With the "at ma"
    I get:
    E8 FF 10 03 B3
    88 25 29 07 00 97
    68 49 10 10 56 90
    E8 FF 60 03 98
    88 3B 10 43 80 0D
    48 FF 40 06 03 AC
    88 53 10 04 C4
    48 FF 40 06 03 AC
    no wonder you are lost... MA will show all the communications that's in that com line
    so, what you are seeing is data packets that are being exchanged between the ECU and other systems.
    What is the make, model and protocol you are using? SP0 is automatic protocol selection. you have to manually select each protocol and see who is responding. probably SP6.
  1. New to OBD2
    By gomidget in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-03-2011, 11:43 PM
  2. Please help me (OBD2).
    By ali3000 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-21-2010, 12:19 PM
  3. OBD2 All In One
    By mastercom2003 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-23-2007, 11:51 PM
  4. in obd2
    By norwegianguy in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-18-2006, 02:41 PM
