Results 1 to 2 of 2
Thread: How to determine what OBDII sensors my car has - 2010 Cadillac Escalade
    Apr 2013
    The Escalade is getting forced induction as soon as I figure out my gauges. The more gauges I can fit via the touchscreen the larger the screen I can use for my CarPC as the real estate for gauges won't eat up the space. My expectation is that some of what I want is missing, but wondering what is there.
    What I'd like are:
    -Boost (going to need a boost gauge for adjusting anyways, but I'd rather have it sort of hidden if I can have a virtual gauge)
    -Fuel Pressure
    -Oil Pressure
    -Oil Temp
    -Trans Temp
    -Water Temp
    -AFR
    -EGT
    I also haven't seen if any of the OBDII software modules can flash a warning around limits on any of these. Any sort of visual stimulation would be stellar.
    Apr 2013
    I have a craptastic BAFX Elm 327 bluetooth with Torque Pro on my tablet.
    Shows AFR, but it is calculated. Measured comes up blank.
    There is no oil pressure listed, but the display in the dash will show it.
    EGT is blacked out so no sensor found on the Elm.
    Trans temp doesn't show up, but again is displayed on the dash
    Fuel pressure can be displayed, rail pressure sensor not found in the software
    Oil temp allows me to select it, but it comes up blank
    Boost I don't see, but would assume vacuum is there...forgot to look as the above were frustrating me.
    Intake air temp works
    So, will a different OBD module help? I assume there are other features rolling around on the bus...just not sure how to access them.
  1. 2006 Cadillac Escalade Ext
    By silentkiller187 in forum Show off your project
    Last Post: 03-06-2011, 01:41 AM
  2. FS: Cadillac Escalade Custom Dash (with pics)
    By EsKALad in forum Classified Archive
    Last Post: 06-27-2006, 08:16 AM
  3. FS: Cadillac Escalade Custom Dash
    Last Post: 01-02-2006, 10:26 PM
  4. 2000 Cadillac Escalade
    By F3rr3r in forum Worklogs
    Last Post: 05-27-2005, 12:23 AM
  5. cadillac escalade bose system
    By EsKALad in forum Car Audio
    Last Post: 05-06-2005, 12:11 PM
