Results 1 to 7 of 7
Thread: Rapid Packet Datalogging
    Jun 2015
    Fulshear, TX
    Howdy!
    I'm trying to datalog a vehicle with a Raspberry PI 2 and a USB OBDII connection. I don't seem to get a very high resolution (30ish per sec). How do you enable rapid packet mode (200ish packets a second) Or is the PI 2 just not powerful enough?
    Thanks for any suggestions!
    May 2012
    Grandville, MI
    Could be the Pi but more likely your adapter... You need to have a fast adapter to get fast readings.
    Jun 2015
    Fulshear, TX
    Quote Originally Posted by redheadedrod View Post
    What adapter is recommended for this? I thought all OBDII adapters were the same. :-(
    Jul 2015
    What kind of vehicle are you trying this on?
    30 per second is pretty good, I don't think anything is wrong with your setup.
    Jun 2015
    Fulshear, TX
    I've tested this on a 2013 Ford Mustang, and a 2012 Lincoln MKz.
    I've seen other datalogger achieve 200 per sec on the Mustang. I'm mainly want to be watching for spark knock and I don't want to miss that event.
    Thanks!
    Jun 2015
    Fulshear, TX
    I've tested this on a 2013 Mustang, and a 2012 Lincoln Mkz. Trying to watch for spark knock events and I don't want to miss any.
    Jun 2015
    Fulshear, TX
    Just to update this thread. Like what RedHeadedRod said, not all adapters are the same. The ELM327 is a old and slow chip. I have purchased a new STN1110 based adapter and will report back findings when it get's here.
    Car is a 2013 Mustang, which supports Ford's Rapid Packets or DMR. Just not sure how to access DMR vs standard OBDII.
  1. Intel Rapid start
    By natanel in forum M4-ATX
    Last Post: 07-14-2014, 12:18 PM
  2. Th!nk City EV datalogging
    By bastenj in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-16-2013, 11:57 AM
  3. how to analyze KWP2000 data packet?
    By winterdu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-01-2010, 02:55 PM
  4. Mitsubishi EVO 8 Install..all in dash, datalogging, tuning etc
    By mchuang in forum Show off your project
    Last Post: 02-06-2008, 08:47 AM
  5. pda for datalogging & mp3 files?
    By kgj in forum Input Devices
    Last Post: 05-15-2006, 03:15 PM
