Results 1 to 7 of 7
Thread: OBD-II Info
    Maximum Bitrate SiGmA_X's Avatar
    Jul 2003
    Portland, OR, USA
    OBD-II Info
    I want to do OBD-II with my CarPC, but I can't find a lot of info to interface it with. I am sure its possible but.. Can someone who has done this pop a msg up with some real info?
    Thanks!
    1993 BMW 325is - 15.2sec
    Sep 2002
    Worcester, MA
    this is a good page
    obdII
    Aug 1999
    Washington D.C.
    OBD-II is fun, you can check error codes just so long as they are emissions related, it won’t help you with vehicle specific things like transmission, air bags, ABS, etc. Those codes and information are tightly protected by the automotive companies (you’ll have to talk to your Congressman to get that changed, I’ve been begging for years). But OBD-II will let you query about a dozen engine perimeters, such as vehicle speed, engine speed, coolant temperature, air intake temperature, etc.
    Jul 2003
    Portland, OR, USA
    I just need the speeds and **** I don't really care about the rest, but it would be nice to get some transmission info.. Is there something that can tell when I up/down shift? (It's a manule)
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    You can get transmission codes with OBDII as well as engine codes. The public codes are powertrian which cover engine and transmission.
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    where can you get software to read all those codes (except writing it yourself of course)?
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Try this one, it's free.
    http://www.obd-2.com/#download
