Results 1 to 10 of 17
Thread: monitoring systems?
    Jun 2003
    monitoring systems?
    i am courious about some of the programs out there that can monitor a cars performance? anyone know of them? and maybe what i would have to do to tap into the cars puter? maybe something with the dia port?
    and something else that has been on my mind where or how can i get a hold of a rta type program??
    Newbie b5b4you2's Avatar
    Oct 2003
    San Jose CA
    if ya got a Volkswagen or Audi I got the perfect program.
    What you sportin???
    Jun 2003
    I have a 1996 jeep cherokee sport. my freind who is really intrested in a program has a 1999 grand prix gt.
    Newbie Twiek's Avatar
    Sep 2003
    Shelbyville, KY
    Both your and your friend's cars have OBD-II, so you could hook up a reader to the computer and read that information. Unfortunately, there aren't many electronic components on the Jeep (compared to other modern cars), and the ones there are aren't coordinated/bussed in any way (i.e. BMW's bus system), so you're pretty much limited to what the OBD-II can tell you (Speed, RPM, Engnie Load, Coolant Temp, O2 guages, Error code reading, etc.). I'm not sure what additional informat you could pull out of the Pontiac.
    Constant Bitrate mugu's Avatar
    Oct 2003
    San Antonio, TX
    Is there a central listing? I checked one OBDii site and it said my year wasnt supported, bu the year after mine did. It would cool if i could run that shtuff. I havent frisked my car for the interface yet.
    Jun 2003
    so is it possible to change settings in the vechicle through the odb11? stuff like the shift points, idle controll, stuff like that? I think that is what he is wanting to do, not just a monitoring system. He also said something about using an interface directly on the cars computer, not so much throught the obd port.
    Oct 2003
    Orange County, CA
    no OBD-II is mainly for monitoring, some cars allow modifications such as those through another tool that hooks up in the same way. most are ford or chevy's. I have seen a MUT-III tool for mitsubishi that lets you change fuel maps but the tool is $5,000 and only sold to dealers.
    There are other ports on most cars now for these such tools but only on the newer models (1996 and later i believe and the reprogramming hasnt become popular till mid 2000)
    Oct 2003
    St. Louis, MO
    Try Auto Tap, no you can't make adjustments, other than turning off the check engine light, but you can monitor quit a bit of information and it is displayed on a computer.
    ~Terpy~
    BigGrandCherokee.com
    Sep 2003
    terpy, none of thoes links in your post work for me..
    Constant Bitrate icecore's Avatar
    Aug 2005
    Estero, FL
    How can I monitor my engine data on my vw?
