Serial is a lot easyer to program, i looked at some USB stuff just to control some relays and would never go thru such a process to send a few volts
there are manufacturers of USB components (that can with a little bit of soldering become relay controls) that have all the work for you done in modules.Originally Posted by owenjh
but in the end serial adapters and parallel port adapters are always cheaper![]()
I have the scantool as well, but it was way cheaper when I got it I think.
I only wish the software was better. v2 is supposed to becoming out b4 the next ice age.
If the code was in VB, I would tackle it.
D
I don't see this listed here anywhere:
http://www.obddiagnostics.com/ Made by Beverly Roadman, and has it's own software that has an option for virtual gauges (one of the things I want to have displaying real-time) AND it's supported by freediag
$88 shipped includes the cable. It also supports the 3 major protocols.
Lacoste
that is prolly the best feature rich software I have seen, but it is still ugly.
Check out http://www.elmelectronics.com/ .They sell interface chips for less than $20, and only need minor($5) parts to complete.Their datasheets have schematics and alot of info too.
There's another option here : http://www.andywhittaker.com/ecu/obdii_hardware.htm
Plus there's also ALDL hardware (including some DIY circuits), if you have an older, non-OBDII car that you can decode.
GingerPrince
Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
Carputer Install - http://www.stuffandting.com/carputer/
CarBox Software -- http://www.stuffandting.com/carbox/
Updating an old (but nonetheless popular) post.
Today, it is safe to say that ElmScan and other ELM32x-compatible interfaces have pretty much won the OBD-II interface war. They are by far the least expensive kind, and are supported by a host of diagnostic software.
They are the only kind of OBD-II interface offered for sale by the MP3Car store
Vitaliy
You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
— Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
in my research these www.obdpros.com were the cheapest with ELM 327 functionality
Arun
