Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Cheapest OBD-II interface/adapter?
  1. #21
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    I am currently working on this:
    http://www.planetfall.com/cms/conten...ics-pcb-layout
    I will let you know if it works. I built the PCB Sunday. I just got some of the parts I need. The calbe will be what's holding me up.
  2. #22
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Quote Originally Posted by bemenaker View Post
    What kind of cable?
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    — Did you know that MP3Car sells OBD-2 interfaces? Get your OBDLink for only $84.99!
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
  3. #23
    Nov 2008
    j1962 to 9pin dsub. I have one on order. I thought I could get the j1962 connector at a local electronics vendor but they didn't have them. The board is sitting here ready to go, I should have the cable on Monday. I will test it and post results as soon as it gets in.
  4. #24
    Jul 2008
    what about something like this..? Unreliable?
    (link should be good until feb 9 09)
  5. #25
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by snbe82 View Post
    Yeah these are not only unreliable but they do not support the advanced features such as
    1. Ability to request a single response from the ECU - this increases the response speed of the interface
    2. Ability to upgrade the firmware remotely - No possibility to get enhaced features when they are release.
    3. Baud rates higher than 115K or 500K
    Paul
    www.obdpros.com
  6. #26
    Jul 2008
    Cool, thanks. I ordered one of yours yesterday.
  7. #27
    VENDOR - OCTech
    May 2007
    I have one from OBDPros and it works great. Tech support has also been very good.
  8. #28
    Newbie sharpmusic's Avatar
    Jun 2008
    Brooklyn, NY
    Does StreetDeck 2 support the OBDpro OBDII interface
    I have been hearing some great things about this interface but I was wondering will it work with streetdeck.
  9. #29
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by sharpmusic View Post
    Yes it will work with streetdeck
    Paul
  10. #30
    May 2009
    i having a mitsubishi triton,
    i removed the RV meter which can show the fuel consumption, the average km/L. L/KM and how much fuel left in the tank, which OBD II is more suitable?
    is that all the adapter is the same? the most important is the software?
