Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: Cheapest OBD-II interface/adapter?
    Jun 2003
    Atlanta/Augusta, GA
    What's the cheapest way to interface into your car's ECU/OBD-II?
    Is it possible to make your own adapter?
    Jun 2003
    Atlanta/Augusta, GA
    Nov 2003
    Sugar Land, TX
    Someone else posted this on another thread: http://www.scantool.net. It looks like you can buy a cable for only $25 and download the software for free. I am not sure if you need additional parts as I have not read in detail. Has anyone actually tried one of these?
    Nov 2003
    Sugar Land, TX
    Actually..I suspect you need the scan tool as well..which is a little bit more than tejesh83's post
    Oct 2003
    Philly, PA
    why are they all serial? is there any USB scanners? my bookpc dosent have a serial port and i would like to avoid useing an adaptor.
    Pontiac Grand Am
    building CarPC useing BookPC and Lilliput 7 inch TS.
    Jun 2003
    Atlanta/Augusta, GA
    From my reading, it looks like you need some sort of chip to decode the signal from the ecu.
    The scantool kit seems to be the best deal. It comes with the cables for only a few bucks more over the multiplex. But, you do have to pay extra if you want a case for it.
    The multiplex one comes in a case, but you need to get at least a serial modem cable. And, if you want to stealth it, you may need the odb cable to relocate the bulky adapter.
    I've read that the chip doesn't cost much. I've also found some schematics on various sites. But I'm not sure if I'm ready to tackle such a project. I would hate to fry the ECU. Maybe a prefab is the way to go.
    If you only got free usb ports, use a usb->serial adapter.
    Nov 2003
    Sugar Land, TX
    it looks like scantool.com sells most of the parts. I'm not ready for that task either. I am good with computers, but not electronics. I'll build a bunch of them, just not from scratch
    Probably worth the $80 just for the peace of mind. It would cost you more then that just for installation if you didn't do it yourself, so it's a bargain!
    Aug 2003
    PDX
    Here's another one. And, as you see on the page, they offer a Serial to USB adapter.
    http://www.dashmatics.com/product_in...products_id=61
    Registered User
    Nov 2003
    Long Island NY
    I have the ScanTool and it is worth the money spent.
    Aug 2003
    Lancaster, PA
    Serial is much easier to program for and a bit easier to manufacture.
