Results 1 to 8 of 8
Thread: iso / vag interface differences?
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    I'm wondering if i could use an obd II cable that works for vagcom/vw's on my toyota... anyone know?
    Jul 2002
    San Rafael, CA, USA
    and if unsure, would it hurt anything if i plugged it in?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    i doubt it will work
    Nov 2003
    Sugar Land, TX
    When you say cable, I guess you mean the whole unit. Cause the cable's are interchangable I think, but the chip in the reader has to be the right type. I really don't know for sure though. I'm very new to all of this myself.
    Aug 2003
    Orange County, NY
    Quote Originally Posted by 00CericaRuss
    Toyotas use the ISO standard, just as your VW/Audi cars. It will work.
    What software do you plan to use?
    I don't believe your VAG-Com software will all that useful for your toyota, as it was specifically written to interface to modules in your VW, but any generic OBD reader software should work for you.
    Jul 2002
    San Rafael, CA, USA
    sweet.. thanks jason.
    the reason why i was asking is because a friend of mine has vag-com, and i'd like to borrow his cable to see if my car is all good. (it can throw codes w/out triggering check engine light) so, yeah... at 50k miles, i just want the piece of mind that my baby is a-ok.
    as far as software, who knows... i'll probably sit in my garage and download a crapload of them, and choose which i like the best
    Aug 2003
    Orange County, NY
    Off hand, do you know if he built his own interface cable/hardware, or if he purchased one from ross-tech when he bought the VAG-Com?
    If he bought it from Ross-Tech, it will work as long as it's one of the serial cables...
    ie: the twin-com or hex-com.
    The Ross-Tech USB cables will NOT work with any application other than the VAG-Com one. They communicates USB via a microprocessor and custom windows driver.
    If homebuilt, almost any serial ISO cable/interface should work for you.
    Hope this helps.
    Jul 2002
    San Rafael, CA, USA
    I'm about 99% positive he has the serial version, and i'm also 99% positive he bought it from ross-tech.
    helped quite a bit... he's already ok'd me borrowing it
