Results 1 to 4 of 4
Thread: Great OBDII Solution
    Nov 2003
    Illinois, USA
    Im new here, but im about to build a carputer, (waiting on all the parts).
    Anyway.. I wanted to tell you guys about a wideband + datalogger setup that you could mount directly into your computer if you use one of the larger computer setups.
    http://www.wbo2.com/
    Check it out and let me know what you think.
    James
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I think I want it. Added to my Wideband O2 favs folder thanks!
    Fabricator
    Constant Bitrate cafn8's Avatar
    Mar 2003
    New Jersey, US
    Sorry about my ignorance, but what exactly is this? Is it only for oxygen sensor data logging, or can it gather other OBDII info too?
    Nov 2003
    Illinois, USA
    It will read real o2 values with a wideband o2 sensor, a must for anyone who modifies their car heavily. You basically use it to tune.
    At the same time, the setup can datalog your car's sensors.
    Basically you can see your air/fuel ratio compared to such things as RPM, boost, air intake temp.. etc..
    Perfect for tuning.
  1. Data logging solution for non OBD2 cars...
    By doig in forum General Hardware Discussion
    Last Post: 11-06-2003, 11:29 AM
  2. 1994 Saab 900 & OBDII
    By Shark in forum General Hardware Discussion
    Last Post: 11-03-2003, 09:58 AM
  3. A good input solution
    By 98_Prelude in forum Input Devices
    Last Post: 05-20-2003, 03:39 PM
  4. Possible solution to the inverter dilemma...
    By gregulator in forum Power Supplies
    Last Post: 08-07-2001, 10:38 AM
  5. Where are the great minds???
    By Fosgate in forum General Hardware Discussion
    Last Post: 11-05-2000, 10:54 PM
