I don't know of any vehicles that actually use the ECU as part of the CC.On a cavalier it would be pretty easy to control the CC.Method 1- there is a CC module under your hood(it has a cable going to the throttle plate), it gets a speed signal from the speed sensor(blue wire at the module if I remember).The speed sensor puts out 4000 pulses per mile, just intercept the signal and adjust it higher or lower.Method 2(easiest)-Use the Set ACC and the Coast wires coming from the switch.When you want it to accelerate pulse the SET ACC wire, when you want it to deaccelerate pulse the coast wire..Either of these could easily be accomplished with minor software and the parallel port(buffered with some transistors).Or with the serial port buffered by a microcontroller with the appropriate firmware.You could use the speed sensor/abs sensor or OBD/OBDII(or a GPS) to get the speed signal.These methods should work on all vehicles regardless of what controls the CC.I can probably help if anyone wants to do this.
LinkBack URL
About LinkBacks
