Results 1 to 10 of 20
Thread: Cruise Control Question
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Just wondering if anyone knows this, i don't know much about cars so
    Does the ECU control and keep the values for cruise control or is it kept on a seperate computer?
    It would be nice to have cruise control which acts like normal cruise control but is activated via my computer - Just a thought.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Depends on the car. Some of them use vacuum to maintain your speed, putting it out of reach of influence of your car PC. The others that DO use the ECM won't be all that willing to allow you to input your own values to set a speed, unless the AutoTap or other software gives you that ability. The thing is, those programs provide an interface command structure to the actual programming language of the ECM, and last time I checked, none of the auto companies take kindly to a private entity trying to break their proprietary property.
    In the end, you can monitor your speed, but it may be next to impossible to set one of your own with currently available (private sector) technology.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Nov 2003
    NC
    Figures, would be nice tho. Figure they use the same ECM on each cavalier they make and the cruise control is just a $200 option when you buy the car.
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    i wanted to hook up my GPS to the cruise control in order to automatically change my speed based on the speed limit, but i havent figured out how to do it
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Nov 2003
    Detroit MI
    Quote Originally Posted by wizardPC
    Heh, that WOULD be cool, but then again, speed change areas are usually pretty obvious, and that's one thing you would likely be better off leaving under your control rather than forgetting about it and letting the computer do it for you.
    The ALEXIS Project
    Color Coding :
    Nov 2003
    NC
    Well, i was thinking about cruise control for the interstate and having it turn off when yuo hit the brake (not sure how one would go about getting that from ECU) just like the factory control but setting it on the carputer - cool idea but would not be worth the money to implement tho
    Nov 2003
    Detroit MI
    Well, here's a different take on the other idea though: What if it could be connected to GPS and kept track of speed limits in certain areas, then alerted you if you went over by... oh say... five miles an hour? Might be nifty.
    The ALEXIS Project
    Color Coding :
    Nov 2003
    NC
    That is a good idea, I always wanted a radar that detects how fast people are going, then give the local police departments the reports on their units. GPS speed would be nice but I would find it annoying. Would be good if you had a kid, you could see how fast they were going and log it to a file and make sure they weren't racing :-D
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    hello big brother
    Nov 2003
    NC
    I had thought about it with some kind of device on signs that tells the car how fast it could go, but with GPS it would be even cooler. Would be a pain in the butt for the roads you drive every day tho.
  1. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 11:21 PM
  2. remote control button question, any1 know?
    By detz in forum General Hardware Discussion
    Last Post: 07-16-2002, 09:27 PM
  3. Audi 100 cruise control hack :)
    By jol in forum General Hardware Discussion
    Last Post: 04-15-2002, 12:50 PM
  4. simple question - cd changer control
    By tbone in forum General Hardware Discussion
    Last Post: 09-09-2001, 07:51 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
