Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 58
Thread: Old car/engine, non ODB, how to get RPM/speed/temp/etc into carputer
  1. #31
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    It worked the last time I drove the car
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  2. #32
    May 2001
    Oregon
    Here's the link to the picture of the digital dash that I'm working on. http://community.webshots.com/user/umsam
    I just got the layout made, but I only got the voltmeter to work so far. I just started working on it and I'll trying to make it universal so that it will work for any engine monitoring. Like I said in my earlier post, I'm using the "Easy Control" program and PIC microchip for data aquistion and sending the data to the computer via serial port. I might need some help in programming, if anyone can help. I also tried programming in VB, but this is much easier. I got simple VB programs to work with MScomm, but Easy Control is much nicer looking. I'll keep you guy posted when I get more time to work on this.
    66 Mustang
  3. #33
    Jan 2004
    If you don't mind a new-guy pitching in...
    A few years back I built a digital display for my Mustang. At the time I only used a 40x4 character lcd display. I wanted to point out a few things about doing this project.
    1) not all sensors have a 2 wire connector, meaning they don't work as a voltage divider. Some, such as my oil and temp sensor were only one wire. To fix this I found other sensors utilizing the 2 wire, variable resister kind.
    2) most sensors for analog gauges are not linear. Meaning you'll have to use a look-up table to computer the actual values for given voltage. You may find these values on the net, but I simply took them to a physics lab, put them under measurable conditions, and measured the resistance.
    3) For most (at least mine) Fuel Injected engines, Central Fuel Injected included, have a square-wave generated by the distributor feeding into the ECU (engine control unit) this is perfect for tach readings, as i don't recomend reading off the coil.
    4) If you have cruise controll, you probably already have a readiably available source for your spedometer. Most cruse controll systems have either an adapter on the spedo cable gear in the tranny, or a hall-effect on the drive shaft (or whatever it's called on a front-wheel drive). If you don't have cruise control, as mentioned, Dakotah Digital makes a sensor that goes into your tranny, just like you original cable one, this will give off a pulse in ratio to your speed.
    5) I also don't recomend using a freq-voltage converter for these applications, mainly because of the resolution you require for an acurate reading. FVC utilize a charge pump to generate the voltage, depending on your ADC (analog-digital converter) you may not get the resolution you want. I do however recomend using the Timer/Counter registers on many of the PicMicro microcontrollers. This is an 8 to 16 bit register that increments on the rising edge of a pin attatched to that register (or falling edge if configured that way). When measuring freq, I simply cleared the counter register, called a delay for a certin amount of time then read the value, say I waited for 0.5s and the value in the register was 100, then the frequency is 200 times a second
    I have a simple schematic consisting of a zener diod, a cap, and a resister that will take a dirty ~12vdc input down to a clean 5vdc. I use this circuit on all inputs to my microcontrollers.
    BTW, the pic16f628, which sells for about $3.50, has 3 counters, 1 8bit and 2 16bit.
    I wish I had some pictures, but that was over 3 years since I had the car. I am about to do the same thing again, when I finish my home-made keyless entry, remote start, alarm system.
    If you have any question just ask. If I made a mistake please correct me but the information provided is to the best of my knowledge and is offered without any warrenty of any kind.
  4. #34
    Jan 2004
    Oh, and for my new project I do plan on running the display from my SBC (single board computer) to increase the asthetics. I'm working with a home-built linux distro, I have my port access through a PCI card I built. The software for access is compiled into the kernel for very fast access. I've never worked with VB, so I can't offer any help there. But I do work in C/C++, java, and python, mostly for a linux system though.
  5. #35
    May 2001
    Oregon
    Hey fastmoneywheel, Can you post or email me your "simple schematic consisting of a zener diod, a cap, and a resister that will take a dirty ~12vdc input down to a clean 5vdc." I'm doing the same with two resistors and a zener diode, but your design might be better. Oh, thanks for the info on the other stuff. I also use 16f628, it's so cheap and functional, includes 2 comparators and its own clock, only if it came with its own voltage regulator.
    66 Mustang
  6. #36
    Jan 2004
    I got this schematic from a friend of mine who built his own programmable electric ignition for carburated 302's (ford). I'll try to draw it here
    input >-------/\/\/\/\---------------------------->output
    ............................................---.........\__
    ...........................................___.... .......___
    *note* dots are there because spaces disapear when this was posted**
    Ok, input goes though a .01K (10) ohm resister then a 1000pf crematic cap to ground, a 5.1v zener diod to ground, arrow or strip of diod towards input stream, then to microcontroller, or whatever.
    I also have a very good PSU unit for cleaning up the 12 volt supply that I use for my electronics...it's quite a bit more complex then this circuit. Leave me your email if you want it.
    It's clean enough to use an ISD400X series voice record/playback unit, which if you don't know needs a very clean powersupply.
  7. #37
    Jan 2004
    Kentucky
    Here is a diagram of this for those who could not understand the above example...
    Just a lil helper fastmonkeywheel
  8. #38
  9. #39
    Raw Wave
    Jun 2003
    fastmonkeywheel,
    Just a thought...
    The circuit you described is basically a voltage regulator and can sure work for PICs.
    I dont know how the 12V is provided but it may be floating when its supposed to be a zero volts. This leave the input of the PIC on a floating state and can cause unexpected results. I know theres a weak pull-up options on PICs but what is needed is a pull-down.
    If for example this 12V came from a relay, then its a case of a 12V or a float situations. Adding a pull-down resistor should easily fix this problems.
    Unless I already missed something
  10. #40
    Jan 2004
    Ricky327, that's a good point. I use this circuit for switch input. Such as my doors or my trunk, whatever. I did use it for another input for something else, and it wasn't working right! I probably need a damn pull down resister...good call
    I'll search for that jpg and email it to you
  1. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  2. My Chevy Tahoe and carputer
    By reggiek945 in forum Show off your project
    Last Post: 05-24-2004, 12:13 PM
  3. Full carputer stereo replacement? Opinions Welcome.
    By jasonsp6 in forum General Hardware Discussion
    Last Post: 12-27-2003, 12:42 AM
  4. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 11:10 AM
  5. help - starting up carputer
    By tilezzzzz in forum Power Supplies
    Last Post: 06-18-2003, 01:52 PM
