No, but i have a SAAB 9000 and would be very interested in any info peopel have to give
Has anybody had any luck with saabs and OBD 1? There is very little information out there.
anyone get any type of OBD interface working with a 2002 Saab 9-3?
I can't answer the original question about older OBD1 cars. You might try looking over at http://www.saabnet.com if you haven't already. That is a fantastic resource for Saabs.
Regarding the 2002 9-3, that car is OBD2 compliant. I believe the 2002 9-3 uses the ISO interface, and the newer 2003+ models of the 9-3 use CAN. I own the obd2allinone scan tool (http://www.obd2allinone.com) and it works great with the 9-5 using the ISO interface.
what kind of data are you pulling from your 9-5's OBD-II shumley. Ive been toying with the idea of building another car mp3 player (after a 7 year car mp3 hiatus, yeah , that long ) and Im trying to motivate myself to get back into it. OBD-II data might do the trick
On a Saab, you are pretty much limited to the SAE standard OBD2 functions. I have not seen any OBD2 software that provides access to Saab-specific data or features. So basically you get the ability to read/clear fault codes and read the standard emissions-related powertrain sensor data (which includes speed, RPM, temps, fuel trim, O2 sensors, etc.). The only tool I'm aware of that can read Saab-specific data and set vehicle programming options is the official GM Tech2 tool that the dealers use, and it is quite expensive.
