Results 1 to 9 of 9
Thread: Is this a OBD-II socket ?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    ok I have a renault Laguna 2002, under the ashtray theres this plug
    now does this look like a OBD-II ?
    if so.. I'm after a bit of kit and software to enable me to display info on my screen.. any ideas ?
    cheers
    CdR
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    It looks like OBD2 to me, but I'm no expert.
    Variable Bitrate Freeman's Avatar
    Aug 2003
    Australia
    im guessing so too, but a quick trip to te mechanics and youll get a deffinete answer.
    It aint no family car.
    SEE MK2 At : -
    http://www.mp3car.com/vbulletin/showthread.php?t=22810
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    looks like it to me.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    Newbie rdrr's Avatar
    Mar 2004
    NH
    Borrowed from autotap faq...
    Your vehicle must have an OBD II connector that looks like this:
    and has pin combinations representing one of the four OBD II protocols:
    J1850 VPW – The connector will have metallic contacts in pins 2, 4, 5, and 16, but not 10.
    ISO 9141-2 – The connector will have metallic contacts in pins 4, 5, 7, 15, and 16.
    J1850 PWM – The connector will have metallic contacts in pins 2, 4, 5, 10, and 16.
    KWP2000 (ISO142300) – The connector will have metallic contacts in pins 4, 5, 7, 15, and 16.
    The pins are used in the following way:
    Pin 2 - J1850 Bus+
    Pin 4 - Chassis Ground
    Pin 5 - Signal Ground
    Pin 6 - CAN High (J-2284)
    Pin 7 - ISO 9141-2 K Line and ISO/DIS 14230-4
    Pin 10 - J1850 Bus
    Pin 14 - CAN Low (J-2284)
    Pin 15 - ISO 9141-2 L Line and ISO/DIS 14230-4
    Pin 16 - Battery Power
    If your connector has extra pins, don’t worry. Manufacturers can use them as they see fit.
    Feb 2004
    Manchester
    thanks fella.. looks good :-) just got to decide if autotap is worth $200, I mean the only benefit really is so I can show off to my m8's.. lol
    Mar 2004
    Quote Originally Posted by CdRsKuLL
    No need to spend $200 when you can spend $99. Check out Digimoto.com
    http://www.digimoto.com.
    Digimoto enables you to do 0-60 & standing 1/4 times, as well as plot power & torque.
    I ordered online, their Elmscan ISO interface, software & cables. Works fine on my Rover45TDi. Took just 5days to arrive and including £14 UK vat, cost £85 - you pay the vat when collecting it from your local Royal Mail sorting office.
    Just check which protocol you need as they do offer interfaces for all 3.
    You can download free software to use with the interface from:-
    http://www.Scantool.net
    http://www.wgsoft.de (digital dashboard display)
    Constant Bitrate slffl's Avatar
    Jan 2004
    Does the digimoto software update as fast as it shows in the flash demos? I've seen some other OBDII software and it updated slower than this.
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    I believe it depends on how many sensors you are looking at.
  1. can some one recomend a OBD II reader
    By crash893 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-05-2011, 06:55 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  3. OBD II RS232 or USB Interface
    By bklynkaos in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-24-2006, 12:42 PM
  4. OBD II Interface with Software
    By cpeek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-07-2004, 01:53 AM
  5. obd II datalogger building and software
    By backpack09 in forum Off Topic
    Last Post: 08-22-2002, 09:03 PM
