Results 1 to 6 of 6
Thread: avoiding extra repairwork
    Jan 2004
    SC
    out of curiosity, has anyone used their obdII capabilities in catching a mechanic trying to overcharge or charge for unneccessary work?
    btw, i'm really not trying to perpetuate a stereotype of shady mechanics, so no offense to any of you out there
    Mar 2004
    Metamora, MI
    OBD2 information only tells you what the likely involved system is. It doesn't tell you what the fix is. There is still hard core diagnosis to be done. Think of the OBD2 codes as just another symptom (but usually a symptom that should be highly weighted in diagnosis). So, one should use caution when saying that the OBD2 code condemmed a technician of "overcharging". Just because a code says "02 sensor voltage low" doesn't mean that there is a problem with the O2 sensor. Could be the connector, the wiring, the ECU, a ground problem, a voltage supply or many other things.
    Kinda like a doctor saying your blood pressure was high and therefore you need a heart transplant. If he charged you for additional diagnosis - would that be overcharging?
    Jan 2004
    SC
    i got that, but i figured that among the people using obdII on this board, there might be someone who knew about car stuff (i don't), examined the flagged system, found the problem, and then maybe took it to a technician just to see what they had to say...i also understand that such a person, knowing that much about cars, probably wouldn't need a repairman anyway
    but that's what i'd do if i knew anything at all about car mechanics and i wanted to see if anyone had any such experience
    Maximum Bitrate none's Avatar
    Sep 2003
    Quote Originally Posted by skippuff54
    Exactly. Nobody but me touches my car unless a $1000+ tool is needed, for exactly the reasons you alluded to: honest mechanics are rare.
    BTW, if anyone in SLC, UT has a VW or Audi, I recommend Alpine Foreign Service on 900 south - they are that rare breed, and fast and cheap, too. (There are a few $1000+ tools needed on Audis. )
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    As a mechanic I will say one thing, I always put the customers parts on the passengers floorboard so there is little to no question of what was replaced. I would encourage you to ask what was replaced and dont be afraid to ask for the parts back! Most mechanics that work for dealerships will agree that we have no problem screwing the company for some extra money but we would never do it to a customer.
    2005 Ford Focus ST
    Sep 2003
    Quote Originally Posted by gospeed.racer
    As a mechanic... customer.
    Yes the best mechanics almost always work for the dealer, and you pay for that quality. If you have a warranty, that is the way to go.
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. Where to connect extra fan?
    By Richie in forum General Hardware Discussion
    Last Post: 01-14-2004, 11:02 AM
  3. need a extra serial or parallel port?
    By Sway in forum Input Devices
    Last Post: 01-08-2004, 07:48 AM
  4. Replies: 0
    Last Post: 09-02-2003, 02:09 PM
  5. irman extra eye
    By cheesyhoward in forum General MP3Car Discussion
    Last Post: 04-09-2002, 04:19 AM
