Hi,
Can someone tell me how do i analyze the OBD information recieved from ECU?
I am using CAN interface and i need to analyse the different data (DTC, Freeze frame ..) and display the recieved information using display interface.
So how do i analyse different types of data recieved from ECU ?
Also, in regards to this thread ~ for J2534 hardware (better pricing then what I saw in this thread), visit www.drewtech.com.
Joel Konecny
Digimoto OBDII Diagnostics
i post here again, i think that no one reply as no one understand what i mean,
i need t know is there ECU emulators so i can try on (flashing memory) ??
There's nothing that'll simulate the entire flash procedure available at any reasonable price. Many ECUs have a boot-block so you won't kill the ECU even if you have a bad reflash. Ford, Chrysler, newer GM's you're ok. Really it's the older VPW GM's that you have to worry most about killing.
