Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: any interest for a cheap obd2 reader?
  1. #11
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    hmn..think you could post the schematics?
    rebuilding carpc... kinda..
  2. #12
    Raw Wave
    Jun 2003
    http://www.elmelectronics.com/DSheets/ELM323DS.pdf
    The diagram is there
  3. #13
    Raw Wave
    Jun 2003
    Heres a full OBD2 project from Elektuur/Elektor magazine :
    Rename all the 3 files back to RAR and unpack...I cant post more than 200KB.
    Use the document for reference or whatever...just dont blame me when things goes wrong.
    EDIT : Look like some didnt get what I meant by rename back to RAR...What I meant is remove all the .ZIP extension so you are left with .RAR extension. Use the software WINRAR to unpack all 3 files. There should be a PDF file in there
    Attached Files Attached Files
  4. #14
    Feb 2004
    the board is the same as ricky327 posted, i just made mine with a 9 pin instead of a 25 pin serial port, i am also going to be adding a turn on relay so that the unit is only powered on when the computer or car is on. There is alot of software out there, www.scantool.net is one. I am also making my own software for the interface that will be strictly a virtual dashboard. far as capabilities, this will read all the suported information that your car can provide to it, check engine codes, and clear them. I might do a usb one also.
  5. #15
    May 2004
    Quote Originally Posted by arkadiyp
    I've looked into ELM products a while back, and unless they've improved them, the product is extremely limited, and IMHO its cheaper to build one of these considering they don't use any specialized parts, and many people here will most likely have everything needed.
    In addition ISO standard does not really require ELM interface, there is a project on sourceforge.net that has software solution. Reason for that is that ISO interface can be understood by RS232 without major modifications to the electrical part.
    what is the name of the project?
  6. #16
    May 2003
    UK
    just go to www.scantool.net all the circuit schematics to build their tool ( ELM323 based ) are there - did the same, cost me under £15 in parts....
    James
    www.digital-car.co.uk - The UK CarPC Forum
  7. #17
    Oct 2003
    Toronto, Canada
    I'm interested! But my car is OBDII-CAN interface. I tried to source a chip that will support the CAN interface, but no luck so far. Maybe you stumbled on one somewhere? Because if so, i would be all over it
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
  8. #18
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    There is one difference between boards out there and that is, some have buffers built in on the interface, so if 'anything' goes wrong, it won't destroy the cars computer.
    Just something to think about ...
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
  9. #19
    Nov 2003
    CT
    good point...you might be able to use the 74367 HEX BUFFER. its what i saw in a parallel port interface schematic. i'm not too sure aobut my electronics knowledge though...
  10. #20
    May 2004
    Arrow
    There are a couple of open source OBD-II software projects available on sourceforge.com. Most of these run on a PC. There are also some inexpensive Palm OS based OBD-II tools available at obd-technologies.com
