tell me about it ! I got a quote from a company for a 1 off PCB - it was so expensive to set everything up for just one they wanted £80 for it !!!
So i ended up doing it myself, i don't have a UV unit so did the old laser toner/clothes iron trick and then going over with etch resist pen for a reasonably neat PCB
James
You meant this stuff :
http://www.maplin.co.uk/products/mod...464&Products=1
Havent really tried it but I heard it doesnt work too well when theres many fine tracks on the artwork.
UV light is probably one of the most useful stuff when playing with PCB. Yes is always expensive for a 1 off PCB. The cost should only be a few pounds if you were to order 1,000s.
Soooo Jamez? We don't care that it's labor itensive, we just want a PCB!!! Lol, seriously, how much is that in USD?
If you want PCB and components based on the simple circuit then go here :
http://www.skpang.co.uk/obdii_hardware.htm
The cables are expensive though.
£ to $ rates is here :
http://www.xe.com/
doing pcb's with toner transfer paper is not that hard, i've done boards in under 15 minutes
Hi PIMPJ!!!
Could you send me the source code in VB you had?
Thanks in advance
email:esteban.trinidad@tigo.nrt.py
Esteban
