Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: any interest for a cheap obd2 reader?
    Feb 2004
    i just made my own obd2 reader, it uses the elm chip it is designed for iso format euros, imports. If enough people are interested i will have some nice pcb boards made up for these. They should be about 2"x1" if everything fits right, able to plug directly into the back of the computer also. Im thinking they will cost about $40-50 for a completed reader. obd2 cable will be about $17. if people are interested let me know and ill get things rolling. I will also be designing the pwm and vpm for domestics also.
    Whistle Tip pimpJ's Avatar
    Metro, TX
    interest - yes
    I'm not in the buying phase yet, but when I get there, I'll find you.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    do they have all of the features of a normal obd2 reader? i don't know a whole lot about obd2 just yet (havent read a whole lot on the obd section), but if they are then im interested cause i dont want to spend $200 or whatever it is for a normal one.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    yeah I'm interested, also would be prepared to be the sole uk import person for these and the send em to everyone else here, if you marked em for $10 value then no import tax would be charged :-)
    Constant Bitrate supralightning's Avatar
    Jul 2003
    Yeah im curious what this might NOT do compared to the more expensive ones out there....
    Vehicle: 2003 Mistubishi Evolution
    PC Specs: 1gHz Nehemiah M10000
    512mb RAM
    Windows XP Professional
    80gb 7200rpm 8mb cache HDD
    UI: MediaEngine 2.1
    Feb 2004
    San Francisco
    I am in aswell, if they offer all the good stuff...not sure what that is though. Also what software will we be using with this.?
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    Thumbs up
    I'm interested also....
    I would just like to see what software it works with and a comparison of how it stacks
    up to the other OBDII products out there.
    Metro, TX
    I'm also interested to see what type of software we're working with here.
    I've been looking for a while now for someone with the VB code to take the OBD data into a usable format, but everyone I've talked to either has an incomplete program, or charges lots of $ for it. Basically I want to take their program and develop a flash front end for it. If anyone has anything along these lines, let me know. I'd be happy to share the front end when I get it done.
    Mar 2004
    I've looked into ELM products a while back, and unless they've improved them, the product is extremely limited, and IMHO its cheaper to build one of these considering they don't use any specialized parts, and many people here will most likely have everything needed.
    In addition ISO standard does not really require ELM interface, there is a project on sourceforge.net that has software solution. Reason for that is that ISO interface can be understood by RS232 without major modifications to the electrical part.
    Never be afraid to do something yourself. Remember - amateur built the Ark, professionals built the Titanic.
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    Could you flip the board over and take a picture of the backside?
    Thanks!
