i wired a DIC into my 1999 grand prix gt and the only info that those things pull from the OBD is the fuel pump informations which it uses in sync with you speed and rpms, to calculate everything it needs
Printable View
Here are some codes from OBDPROS forum.... I would love to code a centrafuse plugin for this....
Engine oil life remaining
E9 4A 00 14
Response is 14 XX
XX converted to decimal divided by 2.55 is the percent oil life remaining
Unlock car doors
Force the interface into VPW mode by issuing
>ATSP2
Now set headers to address the correct module
>ATSH 8A C5 A1
Now To unlock doors Type in
>A1 26
To Lock Doors type in
>A0 26.
==Change Interior light brightness:==
A8 DF 40 91 80 1E sender: manu spec recv: BCM
XX XX XX YY ZZ XX
YY - command?
ZZ - brightness
==set High beam dash light:==
off - 8A EA 40 20 91 00 9B
on - 8A EA 40 A0 91 00 5B
== Tachometer ==
88 1B 10 10 XX 0D 11
xx = rpm * 100
== door adjar Indicator==
on - 8A EA 40 A0 A5 00 B7
off - 8A EA 40 20 A5 00 77
== trunk open Indicator==
on - AA EB 60 A0 A6 00 6B
off - AA EB 60 20 A6 00 AB
== brake light ==
8A EA 40 20 98 00 8D
==Make radio beep:==
68 96 XX 91 YY ZZ
ZZ - number of times to beep
YY - style or duration of beep
==Kill everything in the interior of the car==
28 FF 40 06 03 00 0B 0B
==send out by radio upon button presses - chechsum will be different==
6A A4 80 21 B2 01 58 - tune fwd
6A A4 80 21 B2 FF 81 - tune rev
6A A4 80 99 B2 01 BC - seek up. alternates btw this and the below
6A A4 80 99 B2 00 A1
6A A4 80 99 B2 02 9B - seek down alternates btw this and the below?
I am taking the leap to remove my Factory Headunit and replace it with a touchscreen. I would really like to keep the DIC usable. Options are: Relocationg, Figuring out how to control Via Carpc, Metra adaptor kit. I am building a bezel for my 7" Touchscreen to fit directly into the dash space for an OEM look, so Single din + Metra kit is not really an option. Relocating may be the only solution, but it seems like a wiring nightmare. When I saw this thread I got excited thinking maybe someone had figured a way out to use the pc to operate basic functions of the DIC.
Has anyone gotten anywhere with this? I'm not nearly skilled enough to program an interface, or I would be all over this.
Thanks in advance for any input.
Nathaniel
Bump
Anyone ever figure this out?
You can always do something like this
http://i21.photobucket.com/albums/b2...2/HPIM0498.jpg
http://i21.photobucket.com/albums/b2...2/HPIM0492.jpg
