Here are some codes from OBDPROS forum.... I would love to code a centrafuse plugin for this....
Engine oil life remaining
E9 4A 00 14
Response is 14 XX
XX converted to decimal divided by 2.55 is the percent oil life remaining
Unlock car doors
Force the interface into VPW mode by issuing
>ATSP2
Now set headers to address the correct module
>ATSH 8A C5 A1
Now To unlock doors Type in
>A1 26
To Lock Doors type in
>A0 26.
==Change Interior light brightness:==
A8 DF 40 91 80 1E sender: manu spec recv: BCM
XX XX XX YY ZZ XX
YY - command?
ZZ - brightness
==set High beam dash light:==
off - 8A EA 40 20 91 00 9B
on - 8A EA 40 A0 91 00 5B
== Tachometer ==
88 1B 10 10 XX 0D 11
xx = rpm * 100
== door adjar Indicator==
on - 8A EA 40 A0 A5 00 B7
off - 8A EA 40 20 A5 00 77
== trunk open Indicator==
on - AA EB 60 A0 A6 00 6B
off - AA EB 60 20 A6 00 AB
== brake light ==
8A EA 40 20 98 00 8D
==Make radio beep:==
68 96 XX 91 YY ZZ
ZZ - number of times to beep
YY - style or duration of beep
==Kill everything in the interior of the car==
28 FF 40 06 03 00 0B 0B
==send out by radio upon button presses - chechsum will be different==
6A A4 80 21 B2 01 58 - tune fwd
6A A4 80 21 B2 FF 81 - tune rev
6A A4 80 99 B2 01 BC - seek up. alternates btw this and the below
6A A4 80 99 B2 00 A1
6A A4 80 99 B2 02 9B - seek down alternates btw this and the below?
LinkBack URL
About LinkBacks
