Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Create an OBD Trouble Code?
  1. #11
    Registered User
    Jun 2004
    United States
    Removing the fuel cap won't always set a MIL (check engine light). It depends on if the ECM is running a EVAP monitor test a senses a leak twice.
    The easiest fault I do is pull an injector plug while the car is running.
  2. #12
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Wouldn't removing the O2 sensor do it?
    CarPC install is starting to come along again...
  3. #13
    Registered User
    Jun 2004
    United States
    Not always, some things will immed. set a code (such as a misfire, bad MAF). Some codes are called "two-trip", meaning that the computer needs to see that fault twice to set a code.
  4. #14
    Apr 2005
    Quote Originally Posted by god_of_cpu
    I just finished building my OBD reader program for the ELM chip and I now need to test the Mode 3 and 4 functions for it that query and reset trouble codes. Anyone know of the easiest way to create a trouble code in my car so I can test reading and resetting the trouble codes.
    Preferably something easy to do that won't damage anything?
    Hi!!!!
    I need your help please!!!!
    I am writing code in Visual Basic in order to communicate to the ECU with ELM interface. I donít know very well how to write and read the commands I have to send/receive to talk to the ECU.
    Could you help me please?
    Iíll appreciate your help!!!
    Regards
    e-mail:[email protected]
    Esteban
  5. #15
    Mar 2004
    Metamora, MI
    estaban2:
    Any reason why you posted the same message like a dozen times? It's a waste of everyone's time to reread the same post.
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 01:06 AM
  2. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  3. Comments on BR3 OBD Reader
    By sontakke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-13-2004, 07:57 AM
  4. ? Potential damage to Carputer if dealer connects OBD device ?
    By SAScooby in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-08-2004, 12:56 PM
  5. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 10:01 PM
