Results 1 to 10 of 15
Thread: Create an OBD Trouble Code?
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I just finished building my OBD reader program for the ELM chip and I now need to test the Mode 3 and 4 functions for it that query and reset trouble codes. Anyone know of the easiest way to create a trouble code in my car so I can test reading and resetting the trouble codes.
    Preferably something easy to do that won't damage anything?
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I was thinking about doing that too, and would assume you could just unplug the mass air flow sensor and turn the key on without cranking the engine. You could probably do that with temp sensors as well. Anyone know for sure?
    Mar 2004
    I know on a lot of new cars that if you dont tighten the gas cap all the way you will get a code. You might want to try that
    Jan 2004
    Thanks, for your replies.
    Looks like disconnecting the MAF is the way to go.
    http://g35driver.com/forums/showflat...sed&sb=5&part=
    Aug 1999
    Washington D.C.
    The air intake temperature sensor is an easy one too.
    Aug 1999
    Washington D.C.
    You can also take off the gas cap, don't even have to open the hood for that one.
    Mar 2004
    Metamora, MI
    The gas cap deal isn't instant. There is some tolerance to the ECU reacting.
    another good bet is the coolant temp sensor. This will throw the vehicle into "limp mode" and launch a DTC (diagnostic trouble code). Of course, you will need to clear the code once you are done testing and plug the sensor back in or you will have a sick running car for a while.
    Jan 2004
    Disconnecting the MAF worked like a charm, took about 2 seconds to do and immediatly caused the car to generate a trouble code. Took me about another hour to figure out why I couldn't read it... Turns out you have to send a mode 1 pid 1 message first to read the number of codes before you can send a mode 3 request, otherwise the mode 3 request will respond that the mode 3 request was successful, but won't return the trouble code.
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by god_of_cpu
    I hope you can clear it.
    Disconnecting the battery may not clear it.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Mar 2004
    Florence Yall, BFKY
    He's got the admin password and Mode 4 access rights. I'm sure he can clear it.
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  3. Comments on BR3 OBD Reader
    By sontakke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-13-2004, 08:57 AM
  4. ? Potential damage to Carputer if dealer connects OBD device ?
    By SAScooby in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-08-2004, 01:56 PM
  5. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 11:01 PM
