Results 1 to 8 of 8
Thread: Nology PDA Dyno
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Dallas, Texas
    Nology PDA Dyno
    Here's my OBDII reader: http://www.nology.com/pdadyno
    Jul 2003
    Dallas, Texas
    Oh, and if you do like this option, skip out on the PDA holder from Nology and find your own. I went thru 2, and the suction cup always dies!!!!
    There is also the Auterra software that this is based off of. It is cheaper too!!!
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    How well does this actually work? Do you know how fast the refresh rate is on that? The OBD II standard limits capturing data to 10 times a second and most OBD II readers I've seen are rarly able to capture above 3 times a second. On top of that you can only capture 1 value at a time for RPM, Speed, etc. so if you want to do a dyno or something that needs multiple values your generally not able to get data better then 1 time a second.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Jul 2003
    Dallas, Texas
    I can't quite remember what the refresh rate is right now, but I do remember that it is fast enough to do a dyno with on the PDA. When the correct info for variables are entered, it is pretty damn accurate.
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    So, did you develop this product, or are you just selling it?
    Jun 2004
    It wouldn't be of great tuning use without the ability to use wideband O2.
    The data given wouldn't be all that accurate. You'd be better off with an Apexi RSM or something along those lines.
    Jul 2003
    Dallas, Texas
    Not entirely true! As you can see in the picture below, I have a wideband in my car. BTW, no I didn't develop, nor do I sell this product. I'm just someone who decided to try it over a year ago, and I love it. I was the guinea pig for this product on the http://www.mazdamp3.com forums. It's like having a ****load of gauges in one. You can display up to 5 sensors at a time, reset CEL's (Check Engine Lights), and monitor sensors that most cars don't have displayed. You can see how advanced your timing is...how accurate is your speedo? My *** has been saved by this thing one day when I didn't follow proper procedure to refill my radiator after a flush, and my stock idiot gauge was asleep at the wheel. Anyways, here are a couple of links to the experiences myself and some others have had with it:
    My experience:
    http://www.msprotege.com/forum/showt...ghlight=nology
    Another Mod's experience with Auterra:
    These are both PDA-based solutions.
    Jun 2003
    Memphis - TN
    Damn this sux! Why cant my car be 1 year newer!
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  1. PDA for remote
    By liquid_smoke in forum Input Devices
    Last Post: 02-11-2007, 02:00 PM
  2. Replies: 2
    Last Post: 05-17-2004, 03:41 PM
  3. PDA as controller?
    By david_594 in forum General Hardware Discussion
    Last Post: 04-16-2004, 02:11 PM
  4. Rewiring a PDA to power a larger LCD?
    By SBmp3 in forum General Hardware Discussion
    Last Post: 03-18-2004, 01:02 PM
  5. PDA Keyboard
    By grandamp3 in forum General Hardware Discussion
    Last Post: 08-28-2003, 09:08 AM
