Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Universal OBD-II Scanner
    Constant Bitrate Avalerion's Avatar
    Jun 2004
    Hamilton, NJ
    Exclamation Universal OBD-II Scanner
    In case this hasn't been mentioned, there is a company that sells OBD-2 scanners on eBay. I bought one a few weeks ago and it's amazing. It worked on 2 Toyota Camrys, 1 Mercury Sable, 1 Mazda Protege (Mine), and a Toyota Corolla. I haven't seen any good universal ones posted, so this is a heads up. The software is amazing too. It's not cheap-o software.
    http://autoenginuity.com/
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Link doesn't work.
    Mar 2004
    Quote Originally Posted by Avalerion
    Looks like a nice little tool, on the expensive side though. Their claims on what it does are not all true. First of there are many tools that offer those features. Second VIN reporting is not done by most OBD scan tools because its not always accurate, especially if the ECM is having problems. Also I am not sure, but going by what I remember all the cars that you listed use the same protocol, so the claim of tested universality is not really true.
    Never be afraid to do something yourself. Remember - amateur built the Ark, professionals built the Titanic.
    Mar 2004
    Metamora, MI
    Looks like a nice little tool, on the expensive side though."
    This is actually on the "cheap side" for a true diagnostic tool. Most of the "tools" discussed in this forum are really not true workshop grade or capable devices. They are OK for the purposes of CarPC use, but not for rigorous shop use or for the capabilites that a shop needs for real diagnosis. Shop grade tools start at $1000 and go way up from there (hardware / software).
    "Their claims on what it does are not all true. First of there are many tools that offer those features."
    This is a very difficult "apples / oranges" comparison.
    "Second VIN reporting is not done by most OBD scan tools because its not always accurate, especially if the ECM is having problems."
    It's not that scan tool companies don't "do it" because of accuracy, it's that each OEM uses their own formula and bit structure to represent VIN (and lots of other data). So, the trick, which is always underestimated by aftermarket scan tool companies is reverse engineering the vehicle's electrical architecture to accurately get and transform the data to meaningful values.
    " Also I am not sure, but going by what I remember all the cars that you listed use the same protocol, so the claim of tested universality is not really true."
    universality pertains to OBDII generic level, which is mandated by US government to be standard. The challenge is to find a tool that supports enhanced mode for all those different brands (doesn't exist in the market). Some company's scan tools do a better job than others on completeness of coverage. And, this is the majority of what you are paying for for a "professional" scan tool - completeness and accuracy of the data displayed. This is a huge task for any company, and completely outside the resources of the very small company scan tool products that you typically read about on this forum.
    FLAC Chairboy's Avatar
    Jan 2004
    Quote Originally Posted by DavidL
    Except of course for the BR-3, $89.
    http://www.obddiagnostics.com
    Mar 2004
    Metamora, MI
    chairboy, not even close. I suspect the tool you mention has less than 50% of the data for any of the vehicles. And that the transforms will not be completely accurate, because it requires validation on each and every vehicle year / make / model / engine combination, as the OEM scan tools go through ($4000 and up).
    Not to mention I don't see it listed that it supports CAN protocol (about 50% of this year's production vehicles).
    This is no offense to the product you mention, as for $89 one cannot expect this level of coverage. Like I said, this is an apples and oranges comparison.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    d00d are you their spokesperson. But seriously, for me, I don't care about CAN because all of my cars are at least 3 years old.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Mar 2004
    Maryland/NOVA
    does anyone else make software like the ones that AutoEnginuity's ScanTool comes with?
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    Feb 2004
    Texas
    Smile OBDScan
    I have been happy with my OBDScan from www.ghg.net/dharrison. It's universal with nice software for troubleshooting and now they have a CAN interface too.
    C.
    Sep 2003
    North Virginia
    the whole point of odb-II is to be universal
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 02:08 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  3. OBD II RS232 or USB Interface
    By bklynkaos in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-24-2006, 12:42 PM
  4. OBD II connector uk?
    By Jamez_Warner in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2004, 05:16 AM
  5. OBD II Interface with Software
    By cpeek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-07-2004, 01:53 AM
