Results 21 to 30 of 38
Thread: Finally got my DFI setup! hehehehehehe
  1. #21
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    You are the man, I gotta say. I've been wanting to turbo my car for a long time, still collecting parts...
    Tidder
    Try RevFE
  2. #22
    Sep 2003
    New Mexico, USA
    Now, speedracer, your engine is the 1.6l block with a 1.9l head on it? I think that's what I read, I just want to clarify.
    Or are the '88 1.9l as well?
    Tidder
    Try RevFE
  3. #23
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    The Turbo parts I found were all stock on a 84 EXP Turbo. Search the junkyards, they are still around but getting harder to find! The turbo works on all the non-H.O. motors. It will physically fit the H.O.'s until they went to the Mazda motor, but the compression ratio makes it a bad idea. Mine is a '88 block and a '91 roller head and intake.
    2005 Ford Focus ST
  4. #24
    Dec 2003
    Portland, OR
    Quote Originally Posted by Tidder
    The '88 GT was a 1.9 H.O., but I swapped out pistons for the flat tops, and we also offset ground the crank to destroke it more. Its a 1.9ish motor
    2005 Ford Focus ST
  5. #25
    Sep 2003
    New Mexico, USA
    What I got is a '95 1.9l. I'm lookin' into the 2.0 head from like a '97 to lower compression. I was fortunate to find an RS turbo exhaust manny. Got a T3 turbo, and also got an intercooler from a thunderbird (?). How much boost can you run?
    Tidder
    Try RevFE
  6. #26
    Dec 2003
    Portland, OR
    still in break in
    So far we have the DFI set to go very rich under any boost, but we still have made 8.75psi@ 4200rpm.....prediction is close to a full bar (~15psi). I will have to buy a 2 bar map sensor if I make more than that.
    2005 Ford Focus ST
  7. #27
    Sep 2003
    New Mexico, USA
    That's freakin' nice. It's the stuff I can only dream about...
    Tidder
    Try RevFE
  8. #28
    Dec 2003
    Portland, OR
    you'll get there. Mine took 4 years of buying parts piece by piece. I had the money, but other toys needed the money more. The tags are from 2000....probably should work on that next
    2005 Ford Focus ST
  9. #29
    Low Bitrate andyhardy's Avatar
    Mar 2004
    Bexhill, East Sussex, England
    Hey guys,
    I've got quite a few contacts in the Ford tuning industry - so if you need any advice/sourcing of parts for your engines then let me know as I may be able to help.
    The common thing for people here when turbo'ing their cars is to use the engine management and inlet manifold etc. from a Fiesta RS Turbo because it makes use of a 2.5bar MAP sensor as standard and uses distributorless ignition, giving a much stronger spark than a coiled setup (I know I know, I've gone against my own words there by having a coiled Cossie setup, but that's something you learn in hindsight!).
    Cheers,
    Andy
  10. #30
    In a barn
    i want a festiva! i wanna GUT it down to JUST metal and cut the springs, then rally the crud outat it. those things are so CUTE! little go carts.. lol....
    When in doubt, moo at things.
  1. Conference in Nashville, TN & Latest news on my setup...
    By tejohnson in forum General MP3Car Discussion
    Last Post: 08-11-2004, 09:49 AM
  2. FS: Car Computer Setup - Everything you need!! Pics Galore
    By EBoundEE in forum Classified Archive
    Last Post: 06-19-2004, 10:41 PM
  3. Pics of my setup -> finally!
    By MP3IAN by Ian Gregory in forum General MP3Car Discussion
    Last Post: 07-25-2002, 12:59 PM
  4. Pictures of my setup - Finally Here!!!
    By jmhenry5150 in forum General Hardware Discussion
    Last Post: 04-08-2002, 11:35 AM
  5. Finally I got some pics of my setup
    By Axkicker in forum General MP3Car Discussion
    Last Post: 05-23-2001, 12:41 AM
