Results 1 to 4 of 4
Thread: obd windows go down
    Jul 2004
    obd windows go down
    hello i have a 99 acura and i was wondering if i could use the odb to control my windows (glass not os), what i was thinking if i push the remote to unlock my doors 5 times the windows would go down (if i push it once it un locks the driver door, if i push it twice it unlockes the pass. door,) and push it to lock 5 times it will roll up the windows. i know you can get an After market alarm with window mod but i want to keepo my FOB, so will this work?
    thanks
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I am new to all this OBDII stuff, but I am almost absolutely sure that your ECU will provide that type of information. It is really meant to report data from the engine, exhaust, etc. I don't believe its going to have the position data from the windows.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Try a search for "Relay Boards" on google for the hardware, then here for interfacing it.
    Edit:: here's a good starting point http://www.quasarelectronics.com/3074.htm
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Mar 2004
    Metamora, MI
    The Body control module is usually the one that will control windows (for those equipped with this control type). It would not be available via the generic OBD2 mode. Only in enhanced with connection to the Body control module (not very common for non OEM scan tools).
  1. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  2. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
  3. Booting another application as windows shell
    By psyclobe in forum Software & Software Development
    Last Post: 02-10-2004, 11:27 PM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  5. new windows shell & 'shell=' for win2K
    By magnetik in forum Software & Software Development
    Last Post: 04-16-2002, 09:47 PM
