Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: SUBARU and OBD-2 ve105 -116
  1. #21
    Apr 2005
    Software now available...
    just to let you know that the software is now available for download from the TARI website - www.tari.co.za
    please take a look and download if you are keen to use it.
    calvin.
  2. #22
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    What type of OBDII -> serial converter does this work with? Will it work with the simple K-Line -> converter that is built with the one chip (MC33290?)?
    And is it possible to export this data to something else, or even have a live graph?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  3. #23
    Feb 2004
    PA, USA
    For that matter, what modules is it compatible with? Will it work with the ELM chip thingee?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  4. #24
    Apr 2005
    obd2 interface
    i have tested the software with connectors made for vag vehicles and those that are distributed with the deltadash software from ecutek (both work 100%), and i'm currently building a prototype for my own interface.
    i havent come across an interface that is built with the MC33290, but from the pdf's i've seen it should work just fine, if built correctly.
    the elm chips seems a little over the top for the requirements of these devices. the obd2 interfaces are very simple stupid devices. there is no need for a chip such as the elm which supports programmable header bytes, adjustable timeouts, etc, etc, etc.
    i'll let you know how the prototype goes...
    calvin.
  5. #25
    twg
    twg is offline
    Apr 2005
    This sounds really interesting, I was in fact looking for some type of realtime monitoring tool for my 2004 Subaru Forester...
    Aside from this software, where is a good place for me to find schematics on building the hardware interface between the OBD2 port (I assume this is where the data comes from?) and my laptops serial port ?
  6. #26
    Apr 2005
    you can checkout opendiag as a start...
  7. #27
    Apr 2005
    prototype completed
    prototype is built - you can view it on the website, some pics. the final unit will be much more aesthetically pleasing than the prototype i promise.
    just need to get it tested now...
  1. OBD connector on 2004 Subaru STi.
    By LESLIEx317537 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2004, 06:10 PM
