Results 1 to 8 of 8
Thread: OBD Diagnostics connected all the time?
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Warrensburg, MO
    Hi Everyone,
    After searching here a long time, I ordered the OBD Diagnostics BR-3, and I got the following email response. I'm very happy that Bev is being very forthcoming about the product and doesn't want to ship me something I'll be dissapointed with, but I'm curious if you guys think she's being overly conservative.
    I suspect that many of you use the device exactly as I have planned, and I was wondering if any of you have experienced what Bev describes below.
    Thanks,
    Rob
    Hi Robert, What we have is mostly designed as a simple diagnostic tool, it
    doesn't have a watchdog timer or any sort of automatic operations, so it may
    not be suitable for what you need. For example, it may loose connection when
    cranking an engine, especially if the battery is low, weak, or weather very
    cold, and the only way to reset it is to unplug it and start over.
    I'll put your order on hold until I hear from you and there will be no problem
    to cancel it if you need to.
    Thanks,
    Bev
    "Rob Lamontagne" <rob_lamontagne@hotmail.com> wrote:
    > Hi Bev,
    > I plan on installing the laptop primarily for other purposes, MP3,
    > XMradio, DVD, GPS navigation, cell phone touchscreen interface, backup
    > camera, etc., And the OBD is only one aspect.
    > That being said, my intention is to be able to have the OBD interface
    > cable connected all the time, and only call up the program when I want it.
    > I don't really plan on using the OBD interface on an every-trip basis, but
    > in the future I may like to access the appropriate information for real time
    > miles/gallon display. What are your thoughts on whether this is a feasible
    > plan.
    > I've read good things about your adapter and software from MP3Car.com user
    > forums. Please let me know what you think. Is there possibly another
    > adapter out there you'd like to recommend that would maybe have better
    > connectivity results?
    > Thanks for being so forthcoming and for your time.
    > Rob
    It won't help you measure the miles per gallon.
    And again, leaving it plugged in may work, but it also may need to be reset
    and the only way to do that is to unplug it and start over. It is possible for
    transients or other electrical disturbances to cause it to loose connection on
    some vehicles, especially while cranking the engine.
    I can't really reccomend anything for you because I've not used anything else.
    Sorry I can't be much help.
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
    FLAC Chairboy's Avatar
    Jan 2004
    I have a BR-3, leave it plugged in all the time, no problem. Only time I had to unplug it was after a dead battery, it acted funky.
    Jun 2004
    Warrensburg, MO
    Cool! Thanks Chairboy. I guess I'll tell her to go ahead and send it.
    Everyone else have the same experience?
    '03 Escape 4WD:
    -Transflective 8.4"
    -Slim Slot DVD+RW
    -RR, DFX 4
    Constant Bitrate Big Zack's Avatar
    Oct 2003
    Quote Originally Posted by Chairboy
    Same here... I have had my BR-3 connect for over a month now. No problems at all.
    I just wish there was a way to set defaults on the application. You have to select the interface, turn on each sensor, select analog gauges, and then maximize each time.
    -BZ
    Sep 2003
    North Virginia
    i have one as well
    ive never left it in for a long time ( the obd port is in a crapy place for vw's) but i have had it lose connection before while testing my brothers jetta i just closed the program and opened it back up and that did it for me
    Mar 2004
    Metamora, MI
    crash893 - u could to to a bone yard and snip a connector out and wire it to your harness above the factory plug so the obd2 isn't in your way. You could also hard wire it to your factory wire harness above the connector if the bone yard is inconvenient.
    Nov 2003
    VT
    Haven't pulled it since the install. Everything running fine.
    Sep 2003
    North Virginia
    Quote Originally Posted by DavidL
    yea i was thinking about it
    it only uses like 3-4 wires ( of the total of 16 pins) so i could just splice them in
  1. Oh where have all the Shutdown Controllers gone (and boot time)?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 05-21-2005, 10:57 PM
  2. OK, one last time...
    By orangewhip in forum General MP3Car Discussion
    Last Post: 01-30-2002, 03:52 AM
  3. Radio and amp connected to speakers at the same time...
    By MattW in forum General Hardware Discussion
    Last Post: 07-18-2001, 10:41 AM
  4. Program that says the time when you press a button
    By brandondere in forum General Hardware Discussion
    Last Post: 02-12-2001, 08:28 AM
  5. leave LCD backlight on all the time???
    By DJ in forum General Hardware Discussion
    Last Post: 07-18-2000, 05:29 PM
