Results 11 to 20 of 29
Thread: question about hardware for ODB-II
  1. #11
    Constant Bitrate Big Zack's Avatar
    Oct 2003
    BR-3 from www.obddiagnostics.com is $88 , USA includes delivery ($98 USD All other countries)
    The interface supports OBDII protocols commonly used in US vehicles: VPW (General Motors), PWM (Ford), and ISO9141 (Chrysler, Asian, and European), and ISO 14230 protocol (also called Keyword 2000). (It does not support the CAN interface)
    Free software is for 32 bit Windows operating systems, such as Win 95/98/ME, or Win NT/2000/XP. Screenshots here: http://obddiagnostics.com/ScrnShot/Winscreen.html
    The OBD II standard requires car manufacturers to include a connector to hook into the system within three feet of the steering wheel inside the car, all you need to do is look underneath your dashboard. I think the Explorer has it just to the right of the steering wheel. Here is a picture of the connector:
    (this one is from a 98 Jeep, but yours should look about the same)
    -BZ
  2. #12
    Variable Bitrate RogerWilco's Avatar
    Aug 2004
    very cool thank you for the response, when i get a chance i'll check that out
    and another thing, what exactly can you control with this thing, i know you can monitor tons of stuff in the engine, can you control your windows, locks 'n stuff?
    And can you control the stock computer control chip in the car through it?
    DAmn can you control engine timings ??? or just monitor them?
  3. #13
    Jul 2004
    Santa Barbara, CA
    Quote Originally Posted by RogerWilco
    OBD stands for on board diagnostics and its centered around emissions controls. I'd say its pretty unlikely you'll be able to control your windows or locks with it. But you can control things like timing and fuel curves, but i think its different for each make and model.
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
  4. #14
    Aug 2004
    very cool
    10 chars?
  5. #15
    Mar 2004
    Vancouver, BC, Canada
    Aside from diagnostics specific to engine and exhaust systems everything else is proprietary vehicle protocols.
    I have a VW, and I got a VAG-COM reader, that lets me do ODBII and access all of the proprietary VW stuff.
  6. #16
    Aug 2004
    Quote Originally Posted by archimense
    would that include locks / windows?
  7. #17
    Mar 2004
    VAG-COM lets me control the different beeps my car can make when it locks, and whether the key unlocks one door or all doors. But that is it, everything else is hard coded.
  8. #18
    Mar 2004
    Metamora, MI
    door locks and windows are not controlled by the engine control module on most vehicles..Usually in the body control module. Keep in mind there are many, many modules in newer vehicles. My Durango has 37. Door locks are usually controlled with another level of security as well.
    You could always hard wire a relay in line with windows / doors that can be controlled via pc.
  9. #19
    Aug 2004
    just as soon as i order all of my parts i'll look into that, i do have the manufacturers manual that people at garages and repair shops use to diagnose your vehicle and has a very nifty diagram, maybe ill see if its in there. thanks for the responses
  10. #20
    Low Bitrate Deliriousvision's Avatar
    Aug 2004
    Scranton, Pa
    i noticed these devices for ford, gm, chevy and whatnot...but what about toyota and other foreign cars? is there a device that supports those interfaces?
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. atari 2600 install / hardware question
    By tracker92 in forum General Hardware Discussion
    Last Post: 07-21-2004, 10:56 AM
  3. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
  4. Newbie question about ODB I and II
    By Nokia6600 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-24-2004, 11:59 PM
  5. Hardware question by a Noob
    By SavedSoul777 in forum General Hardware Discussion
    Last Post: 04-07-2003, 09:53 AM
