Results 11 to 20 of 29
Thread: OBD-II can you use it to...
  1. #11
    Variable Bitrate RogerWilco's Avatar
    Aug 2004
    lucky! must be something to do with america, will i guess it does have its down side, not as though it really matters, except to test my max speed. and to have something to brag about lol
  2. #12
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    is your dad selling a car ??? is that why it wants to reset the odomteter?
  3. #13
    Aug 2004
    haha no, i was just telling him about the ODB-II seeing as i had just learned about it, hes an IT manager also, so i figured he'd be interested. And hes no idiot, hes aware that you could very easily notice that a car was not brand new, yet conveintly had 0 miiles.
  4. #14
    Low Bitrate djtrickee's Avatar
    Aug 2003
    Denver, CO
    Quote Originally Posted by RogerWilco
    but i have to watch out ! my explorer might "flip over"
    Ahhh to dream a little dream.
  5. #15
    Aug 2004
    i've taken a turn at 50 mph, in a 98 ford explorer. completly stock, given the truck did driift and didnt hold tite, it was no where near flipping, i wasnt accelerating so the truck did slow down but i went into the turn at 50 mph. I would'nt make somethin as foolish as this up
    *only once
  6. #16
    Mar 2004
    Metamora, MI
    Roger, in most vehicles the odometer is kept in several modules. You can reset the odo held in the ecu with a factory scan tool in many vehicles, but that won't reset the odo that you see on the dash.
    The "fishhook" manuever is the one that NHTSA uses to rate rollover. Just going 50 in a corner is not simulating the worse case. The fishhook gets the momentum of the vehicle transitioning from one direction to go way over in the other.
  7. #17
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by djtrickee
    I dont think he gets it!
  8. #18
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Governors are commonly used to limit the top speed of the vehicle to that of the speed rating of the tires that came with it. For example my truck came with S rated tires, which have a top speed rating of 112, this also happens to be the same speed that my governor kicks in. Not sure about other cars governors but on my truck the computer drops spark to some of the cylinders to prevent further acceleration.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
  9. #19
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Dodge is right - there's a reason why tall off-roaders are limited - high centre of mass and the tyre limit. Off-roaders are susceptible to flipping as they are - taking it past 120 really isn't a good idea
  10. #20
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    If you want to elminate the governor...you can get a custom chip burned for the pcm and it will take care of that. Problem is your out about $400 for the chip, but later if you make mods to the motor you can have the chip reburned to adjust many parameters. We do a ton of chips on Mustangs, not sure if it would be worth it on a SUV or not, but thats how you do it
    2005 Ford Focus ST
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 01:08 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 01:06 AM
  3. 98 Nissan Altima OBD II? to carputer???
    By tsparks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-30-2006, 09:09 AM
  4. FS: OBD II ISO - Digimoto/Scantool
    By ELEmental59437 in forum Classified Archive
    Last Post: 07-22-2004, 11:22 AM
  5. OBD II connector uk?
    By Jamez_Warner in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2004, 04:16 AM
