Results 1 to 9 of 9
Thread: does this connector means i have obd II ? (Buick 95')
    Aug 2004
    he looks likes obd II ... from the pictures i saw... (sorry for the bad qulity of the pictures.. i took them with my phone..)
    so what do you say is that OBD II ?
    or it somekind of older version...
    cuz from what i understood.. the obd II only start in GM vichels from the year 96 ... and my car is 95...
    but mybe my car is model 96 and was build in 95.... i dont know ... what do u say??
    and is that vpw? (and not iso?)
    thank u all!!!
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by tomer
    thank u all!!!
    You can get the year model from the vin# 10 digit.
    10th character- Identifies the model year. For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T),
    1997(V), 1998(W), 1999(X), 2000(Y)------2001(1), 2002(2), 2003(3)
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Unfortunately, although it seems to be a obd2 port, it may or may not work. I can only go by Ford as that is what I was trained on, there were many late 94-95 models built with dummy sockets that were only there to ready the cars for the upcoming obd2. It is hard to say for sure, but a trip to the dealer would shurely answer that for you.
    2005 Ford Focus ST
    Aug 2004
    thats the problam that they dont really market my car (only the new 2002 + models..) in my country
    it have been coustem imported by the man i bought the car from...
    il ask the garge or something...
    btw... i wannt use obd II
    cuz the "ABS" warning light is working ... and i wanna know what the problam...
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If you in the state, stop by autozone/checkers/kragen and borrow/loan an OBD2 reader to test. If it is a working OBD2 port, the reader will read the code from the ECU. Otherwise, nothing will be read.
    What is the manufacture month? Usually if it is August or later, it is the next year model. 9/95 is acually a 96 model.
    I think it is ODB2 capable, otherwise GM wouldn't spend money to put the dummy port in there. They may have the cable ready, but not the plug. GM would save tons of money by not putting it there.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Newbie jyaron's Avatar
    Aug 2004
    Post
    thank u all!!!
    It's GM UART on Pin 9... not OBD2 VPW
    Dec 2006
    Leamington, Ontario, Canada
    obd2 port
    some gm 94, 95 had the 16 pin 0bd2 port with obd1 system behind it, try reading with a obd1 reader, this can also be done with an analog volt meter, if you need to the the pins for this, let me know, i have a book for every vehicle with obd1.
    Jan 2007
    1996 was just the year that OBDII was standardized as an industry as all cars had to have it. Their were GM cars prior to 1996 that had OBDII. Yours is probably just what I like to call OBD1.5 OBDII connector with an OBD1 computer in it.
    Sep 2007
    Hi
    If your ABS light has come on it may well be dirt in the reluctor plates on the wheels. Behind each wheel is a proximity sensor and a round disc with notches cut into it around the circumference. These notches can get clogged with dirt and the sensor can not pick up. Take the wheels off one by one and use a wire or stiff brush to remove the dirt.
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 02:08 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  3. 98 Nissan Altima OBD II? to carputer???
    By tsparks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-30-2006, 10:09 AM
  4. FS: OBD II ISO - Digimoto/Scantool
    By ELEmental59437 in forum Classified Archive
    Last Post: 07-22-2004, 12:22 PM
  5. OBD II connector uk?
    By Jamez_Warner in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2004, 05:16 AM
