When will you ever learn?
And don't you think that maybe the OBD Forum would be the place for this question?
Edit: thanks to whichever moderator moved this
I was considering buying the elmscan interface in the box for J1850 PWM, i wanted to check and see if anyone have used, and have decent experiences with it. Thanks
http://www.digimoto.com/order.htm
Digimoto Extra Interface (With Enclosure) & Cables (OBD, Serial)
oh, and it costs 89$ before shipping
from digimoto; about OBD II Cable
it costs 16$.High quality 6-foot (1.8 meters) OBDII Cable Type C (J1962 to DB9F), with molded connectors and strain relief. Works with all of our OBD-II interfaces, as well as interfaces made by other scan tool manufacturers such as AutoTap. This cable comes with any interface or package purchased from Digimoto and is not required to be purchased separately.
and what about this ODB-II to serial cable, if i had software could'nt i just use this?
and for refrence, i've searched on this
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
The "OBD2" cable is just that - a cable. No electronics. It is meant to be used with a scan tool elecronics hardware and related software. Here's the chain:
Vehicle ECU (several) <> vehicle wiring harness and plug <> "OBD2" cable <> Scan tool hardware <> Serial / USB / 802.11 <> PC <> scan tool software <> application software (front end)
Yes, I think all you'd need additionally is the software.Originally Posted by RogerWilco
I use this stuff: http://www.ghgcorp.com/dharrison/obdscan.html
at work with my pda, it also comes with windows software. Works pretty good.
Personally I've found that all of this software is pretty much the same. You will only see OBDII related stuff: rpm, mph, o2sensors, tps, coolant temp, and some more, but not much.
You will not see "vehicle specific" trouble code descriptions. You will see the code # (i.e. P1135) but not a description.
All ODBII code start with a "P" and a "0". As in P0446 (EVAP emmissions failure)
It's alot of money to spend for something that is not to exciting. Unless you'd use it at work anyway (like I do)
If I didn't use it at work, or even if I hadn't allready owned the PDA, I wouldn't have spent the money.
Hope this helps?
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
i got the elmscan with digimoto.
its all good.
tom.
I have the scantool.net elm scan with digimoto. It's OK
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
Are you ever gonna learn that linking to a search like that won't workOriginally Posted by wizardPC
right ?![]()
[H]4 Life
I'm a lesbian too.
I am for hire!
no!
I'M DEBT FREE!!
I just ordered mine. I will post a review when I get it.
