Results 1 to 10 of 12
Thread: porsche install ? anyoneeeeee?
    Newbie outdidya's Avatar
    Jul 2004
    NY
    Has anyone installed one of these odbII readers on a porsche? i have read that they are compatible with most cars but i have never heard or seen the 2 words together in once sentence(porsche, odbII). has anyone done it to their porsche ? or maybe heard stories ? have friends who did it ? anything at all. I would really love to install this on my carputer, seems like a sick option to be able to do that. If i had this , i think there would be absolutly nothing left that a stock system could have over a built-in carputer. thanks for the help, hopefully ill get some.
    btw , i tierd searching , absolutly nothing
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Someone here installed ODBII on their Porsche (944?), under Linux no less.
    Jul 2004
    NY
    i dont think that quilifies , cause his car is a 1988 and he installed his own tools to get back info. im pretty sure its different on the new cars. prob a lot more complex. anywayz, im just looking for a cleaning install where i can just plug it in and use the software on my touchscreen. For some reason , i cant find anyone at all with what i am trying to do.
    Jun 2004
    Upstate New York
    Apparently Porsche does use OBD II. http://tools.baumtools.com/iscan_porsche.jsp check the application guide to see if your model has it.
    Mar 2004
    Metamora, MI
    If it was sold in the US since 1996 it is OBD2. The question is whether you can find a scan tool that will get to enhanced data (beyond OBD2).
    Aug 2004
    at home
    Quote Originally Posted by outdidya
    ha ha it's easier on new cars, if only i had obd i would certainely used it but not so sure... obd is a terribly lazy protocol
    have a look on rennlist.
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    Porsche doesn't have ODB systems, they have Bosche DME..
    There was a guy that did the linux box on his 944, but it didn't control the DME..
    good place that explains the Bosch DME http://www.frwilk.com
    Now, the programming could be duplicated on a CarPC
    Hope that helps
    BTW, I have a 85 944
    May 2004
    As I am pretty familiar with the Bosh Motronic systems, I will also be checking into pulling data for display purposes.
    Thats after a couple Car PC's are done etc.....
    Aug 2004
    at home
    Good luck
    unfortunately there's no way to pull anything from the 8051 as the tx & rx ports exists on this chip but it's not programmed for...
    The Franck Wilk's website is good for the 944 series not for newest boxsters and other 911
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    What a nice old thread to bring back to life!
    The Porsche DME can be read with ODB2 but it is limited in what it offers, ideally you need a Porsche System Tester II for reading and diagnosing the codes (amongst other things).
  1. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 03:37 PM
  2. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 03:03 PM
  3. Lilliput 619GL-70NP Touchkit XP Home Install
    By Windchsr in forum LCD/Display
    Last Post: 04-25-2004, 07:23 AM
  4. How to install 98lite?
    By ugosplat in forum Software & Software Development
    Last Post: 07-27-2003, 05:40 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 08:10 AM
