Results 1 to 5 of 5
Thread: Where can I get a OBD-II Extension cord?
    Low Bitrate Udonboy's Avatar
    Aug 2004
    Anaheim, CA
    I just got my Autoenginuity scantool today, and when I plugged it in, I noticed that the actual unit protrudes out to where my legs are and get in the way. There'd be no way I could drive comfortably while having it plugged in. Are there any OBD-II extension cords out there I could buy? I want to be able to put the scantool unit some place where it won't get in the way. (I drive a 2004 Subaru WRX and the OBD-II port is located on the bottom of the steering column, right above where my legs would be while driving.) Thanks.
    Mar 2004
    Metamora, MI
    You might want to look into scotch-locking the scan tool wires to the wiring harness above the connector. That way it will not be in driving way. Put a disconnect on the wire so a standard scan tool can be used as well.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    This site has a low profile cable but no pre-made extensions. Although you could get a cable and a connector and put it on the scantool end.
    Aug 2004
    Anaheim, CA
    Actually, that site has exactly what I'm looking for. A male to female OBD cable. Thanks alot!
    Feb 2004
    save money and just unbolt the connector from the dash and put it some where else
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 02:08 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  3. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  4. FS: OBD II ISO - Digimoto/Scantool
    By ELEmental59437 in forum Classified Archive
    Last Post: 07-22-2004, 12:22 PM
  5. OBD II connector uk?
    By Jamez_Warner in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2004, 05:16 AM
