Results 1 to 10 of 11
Thread: Easy way
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Exclamation Easy way
    Hi
    Witch is the easy way to make a OBDII interface in ISO standart ??
    OBDII <> RS232
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    New York
    As far as I understand this is not possible because of the communication method. I forget the exact number specifics, but it has to do with the initialization sequence that is out of sequence.
    Basically, if the bus is normally at 4800 bits/s, the initialization rate is something like 3 bits/s for i forget how long. If i get find the details again, i'll post it up.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    If you want to assemble your own interface, you can buy an ELM323 chip which is ISO, for around $20 and assemble the rest of the circuit yourself. There are instructions online. It will probably cost you at least another $20 for the cabling and other parts which you'll have to buy regardless of which way you do it, but making your own conversion chip from scratch will be very complicated and probably end up costing you more then $20 in the end.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    May 2004
    Denmark
    Quote Originally Posted by god_of_cpu
    Where can i buy the cable and the Elm323 chip ??
    Ditail at 4u2n.dk
    Here
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    look up elm electronics.
    they have a online shop that post the chip to your door within 14 days.
    I made a VPM one and also a ISO one. Both worked great.
    Ford XR6T blueprint 4.0 L twin cam turbo.
    Xenarc 7" touchscreen M10000 Audigy 2 NX
    ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
    Griffin Powermate Panasonic DVD-CDW
    Pioneer 5x7 Four way, 2x12 pioneer subz
    600watt 6chan USA audio AMP
    Jan 2004
    I got mine from scantool.net
    Oct 2004
    I believe u'd better buy a direct k-line interface...
    ...on my iby (130cv my02) vag-com is doing miracles... while elm's is not... I mean it works, but cannot modify a lot with generic scan tools!
    If u like to wire and solder ur own circuit I've got one using a Motorola chip: actually I'm using this and it works great (but I bought it from www.skpang.co.uk)
    May 2004
    Denmark
    thanks for the info I check et out and make a choice
    Ditail at 4u2n.dk
    Here
    Newbie fearthepenguin's Avatar
    Mar 2004
    Might want to rethink
    I hate to be a stick in the mud, but maybe you should consider buying a prebuilt unit. Don't be offended, but if you don't have the required electronics expertise already, you really dont want to use your cars ignition system as your first experience. But if you still want to try to do your own, I would price out how much a new computer will cost you from a junk yard (be sure to check and make sure it actually includes the chip, as most yards pull them and don't include the chip with the computer) and see if it's still cost efective.
    Jason
    It gimme the jibblies
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    You own a seat so why not just buy the vagcom? OR that ebay cable or that www.obdtool.com connector?
    Mine needs to be updated.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Easy way to run rotary encoders
    By TheLlama in forum Input Devices
    Last Post: 02-15-2005, 05:01 PM
  3. 24 Volts, Possible? Easy?
    By Deadnick in forum Power Supplies
    Last Post: 05-26-2004, 10:47 AM
  4. Cirque Easy with USB converter
    By CoCa in forum Input Devices
    Last Post: 04-02-2004, 08:19 PM
  5. Car radio "hack" is EASY!!!!
    By THEMP3KID in forum General Hardware Discussion
    Last Post: 07-19-2002, 10:48 PM
