Results 1 to 10 of 16
Thread: cheapest ob2 hardware?
    Jul 2004
    Santa Barbara, CA
    where can i find cheap odb2 hardware? odbdiagnostics.com seems to be down..
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
    Oct 2004
    are you looking for just a scan tool or do you want a flasfhing program as well? if you want just a scanner look for autotap. not sure of the web addresse any more bet it's a farly good program and wasn't to expense last time I looked.
    I have a 2000 camaro run hp tuner. it is a scan tool as well as a flasher for tuning everything. if you want a flasher I would highly recommend this program as it is the best out for ls1 engine's to date. however it is not a cheap program at 500 buck's. they web sit is www.hptuners.com I would suggest at lest giving it a look and reading some of the forum's about it there.
    Variable Bitrate wkolodny's Avatar
    DC
    Quote Originally Posted by jrtf83
    Not down. Just mispelled.
    Try this link instead:
    http://www.obddiagnostics.com/
    Don't Fear The Gurkey
    Click here to check out My Setup
    FLAC Chairboy's Avatar
    Jan 2004
    The BR-3 from obddiagnostics works great for me, btw. Very versatile, no special hardware needed to interface with the different car types like some scan tools.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Jul 2004
    Santa Barbara, CA
    Talking
    Quote Originally Posted by wkolodny
    DOH! wow i'm a moron! Thanks!
    -Ross
    02 Camaro SS
    Tot: $983
    Buying stereo!
    Aug 2004
    hey does any know if the BR-3 work with other software then the one from the site?
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    What size screen are you guys using to view the OBD data?
    Does it work well with a 7 inch?
    Jan 2004
    As far as I know, it only works with the software from the site right now, but the spec is published so someone should be able to write another interface if they want.
    I use mine with my 7" lilliput no probs. The software doesn't really interface with the front end I use, so I don't use it a lot, but I've been thinking about writing some sort of interface that would be full screen and do diagnostics, etc. Maybe once I get settled into my new house/job.
    http://hallert.net/
    DC
    I like it mostly. Wish there was an ini file to set the protocol. You have to set it manually each time you start the program.
    Jul 2004
    Santa Barbara, CA
    What about obd hardware that can edit tuning settings? I ordered from obddiagnostics.com but then they told me that thier hardware won't edit any settings in my pcm... :-( I don't wanna have to break the bank with one of these 800 tuning packages!
    -Ross
    02 Camaro SS
    Tot: $983
    Buying stereo!
  1. MediaCar and Hardware???
    By RYAD in forum MediaCar
    Last Post: 05-07-2004, 09:57 AM
  2. Who has the slowest hardware
    By berniejr in forum General Hardware Discussion
    Last Post: 03-02-2004, 01:36 AM
  3. cheapest prebuilt (not homemade) atx and at dc-dc PSUs
    By Punjabi Geezer in forum Power Supplies
    Last Post: 10-29-2001, 06:58 PM
  4. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 11:43 AM
  5. Wheres the cheapest place to get a lcd?
    By Krash in forum Software & Software Development
    Last Post: 11-09-2000, 05:47 AM
