Results 1 to 8 of 8
Thread: Will this be able to read boost?
    Newbie harrisonpowers's Avatar
    Nov 2004
    Westchester, NY
    I'm pretty sure OBD-II can read boost pressure, or I've heard wrong. Anyway, if it can... will this be able to show boost pressure in my 04 wrx?
    If you know one that does, pleas give me a name/link. Thanks.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Seems that this one can.
    Nov 2004
    Westchester, NY
    Damn, that thing reads a ton. Thanks.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by harrisonpowers
    No problem. I bet others will chime in with others, but that's the first thing that came on up
    Nov 2004
    Westchester, NY
    Just got the demo of it and couldn't get it to show any boost, that could be because it's not connected to a vehicle (it should be in presentation mode though)..
    Does anyone know where I might be doing something wrong?
    edit - EcuTek makes the DeltaDash specifically for wrx's. It does not show boost, I have a feeling that I won't be able to get boost via OBD-II.
    Oct 2004
    Boost is usually considered an "enhanced parameter". If this is a general obd2 scanner and not designed to read stuff specifically for your car it probably wont.
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    get delta dash from ecutek.com
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Mar 2004
    Metamora, MI
    The Autotap link you reference is a list of Diagnostic Trouble Codes. It is not a list of real time available data (like boost pressure / map pressure).
    The car's ECU may monitor the map sensor to see if an abnormal condition is being sensed. If so, it may trip a DTC with the issue. That is not to say that you can monitor the boost pressure with your device.
    Map sensor is a fairly standard device to monitor as it is so important to vehicle driveability.
  1. Read The #$^$^ Settings Menus & Steps to get answers.
    By frodobaggins in forum FrodoPlayer
    Last Post: 11-03-2004, 10:15 PM
  2. Has anyone built a boost - buck circuit?
    By starfox in forum Power Supplies
    Last Post: 01-22-2004, 06:16 PM
  3. FAQ's? Do we need em? will people read em?
    By CA 3000GT in forum General MP3Car Discussion
    Last Post: 02-14-2003, 02:27 PM
  4. Reading one thread marks all threads/forums read
    By Micahb in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-11-2002, 03:56 AM
  5. what a dumb-bastard heh, must read
    By crazyshaxs in forum Off Topic
    Last Post: 05-17-2002, 08:56 AM
