Results 1 to 8 of 8
Thread: Can a Daihatsu Charade use OBDII ?
    Malaysia
    I'm running a Daihatsu Charade GTti Turbo engine (1994) in a Daihatsu Charade G11 (1984) .
    Thinking to DIY the 0BD2 hardware from scantool.net . My question is , can i use it for my car ? the diagnosis connector is diffrent too and located in the engine bay .
    Daihatsu Charade G11R Turbo
    I paying my roadtax , car , bike , life insurances , telephone bills , house premium , grocery , anything i pay monthly . But what did i get ? I EARN AND GET EVERYTHING !
    Tainted Love Cris's Avatar
    Romania
    That's not OBDII. Only after 1996 they started OBDII, and mostly in american cars. I don't know what that's that plug, but it looks very different from what I've seen so far...
    Malaysia
    that is the diagnosis connector at my car . weird looking and at the wrong place ? Double check at the manual and that is the car diagnosis connector .
    My car is imported from Japan . so that mean's i can't use OBDI or OBDII ? Hmmm . too bad .
    Romania
    Go to your local Daihatsu service and ask them about it. If the car is scanable, they should know about it...
    Jan 2006
    gtti engine in a g11?
    ive got a g11 and i want a gtti engine and box in mine.
    someone said it wont fit,
    tell me what i need to do to smack it in my charade g11 1983.
    are the engine mounts different?
    what about the driveshafts.
    and all the wiring- can it be DIY?
    Lets hear what the crazy experts have got to say.
    Low Bitrate Coldfusionpower's Avatar
    May 2005
    Malaysia , Asia
    Quote Originally Posted by g11rallysports
    well ... GTti can fit perfectly in G11 chasis but need new mountings . driveshaft are custom made or was cut from the original GTti and welded back together with the proper length . i'm not to sure about the wiring ..
    well , in my country , there are some people using Toyota Starlet 4E Glanza in their G11 .. it just fit in barely ...
    back to the original topic , i alredy tried asking but they have no idea about the engine i'm using .... well , figures since they didn't have any sparepart for the engine i'm using . have to imported it either from japan or australia .
    anyone can help on this ? make the obd2 pinout DIY to the ECU or somthing ?
    First 3 Version DONE ...but sold ..with the car .. now .. building another one for the new car .
    Coming Soon : CarPC 2.0 .. 40%
    Aug 2006
    hello my friend , i am one of the creators of gtti-Hellenic club here in greece!
    Thats is not odbII!
    It is the diagnosis connector, and if you short the upper left with the down pin, you can see if there is a problem with your car, consideribng how many times the engine light in your dashboard will flash!
    you can find more about diagnosis error messages at www.daihard.org under Faq!
    i have a gtti, and i think we do not have odbII connector.
    Maybe there is something where your ECU is!
    Yes engine swap between g11 and GTti is very common, because g11 is lighter than gtti, but you have to make up your brakes and suspension, to feel safe! (You can also fit GTti engine into Cuore too! ;-))
    You can join our club www.GTti-Club.gr to find more!
    my email is asimak@ccf.auth.gr
    cu!
    May 2005
    Malaysia , Asia
    owh .. too bad .. maybe the best way is install a stand alone management system .. hehehe .. want to put Microtech LT8XS ..
    Mod can close this thread ..
  1. sample for in-car OBDII output on 20x4
    By Telek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-23-2007, 11:51 AM
  2. OBDII for Hyunday?Link?
    By mauri in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-21-2005, 11:28 AM
  3. Which OBDII to buy???
    By smonice in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-27-2004, 07:42 PM
  4. 1994 Saab 900 & OBDII
    By Shark in forum General Hardware Discussion
    Last Post: 11-03-2003, 08:58 AM
  5. OBDII information spec request
    By Telek in forum General Hardware Discussion
    Last Post: 12-02-2002, 10:40 AM
