Results 1 to 6 of 6
Thread: Rover Turbo
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    Rover Turbo
    Hi All I Have Rover 600 Ti (turbo 220bhp) Made In 1997 Does Any One Know If It Can Be Pluged In .
    I Think It Should Be The Same As Honda's System
    AND IF IT DOES IS IT POSSIBLE TO CONTROL THE TURBO PSI OUTPUT ?
    THANKS
    Low Bitrate khemical's Avatar
    Jun 2004
    DeKalb
    Quote Originally Posted by skydiver
    THANKS
    It is made after '96 when it was mandatory in America, so in all probability, yes. For the psi? don't know - you would have to find a spec sheet for its individual interface.
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Hi Skydiver... I have a 95 230bhp Vitesse ;-)
    As far as I know there is no way of plugging the ECU into a PC, unless your a Rover Dealer and then the program only reads fault codes...
    I've looked all over and even on Rovertech.net they say its not possible without a lot of investment. Cheaper to buy a new ECU with OBDII output.
    Do you have a CarPC setup yet?
    John
    Nov 2004
    southampton (UK)
    hi vitesse .
    pc not finished yet i have
    Globalsat BU-303 USB GPS
    Lilliput 7" Touchscreen
    1ghz dell optiplex form factor
    Mediaengine & WinXP Pro.
    destinator3
    few more weeks left
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    <<<< another vitesse turbo owner
    Welcome to the club Skydiver (and hi again John )
    Your further along than I am on the build, well done, I hope to have mine in by springtime latest.
    Nov 2004
    southampton (UK)
    thanks Mad Ad nice to be here
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
  1. Feedback needed for new Range Rover install
    By ratchtjaw in forum General Hardware Discussion
    Last Post: 12-11-2005, 11:33 AM
  2. 92 range rover speakers cutting out
    By MAXXMODDER in forum Car Audio
    Last Post: 12-09-2005, 04:40 PM
  3. Turbo readouts from OBD?
    By moonshinemadnes in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-31-2004, 04:53 PM
  4. Rover Turbo Coupe / Xbox-Linux
    By MegatronUK in forum Show off your project
    Last Post: 03-08-2004, 10:34 PM
  5. Status of my RX-7 turbo conversion
    By Aaron Cake in forum Off Topic
    Last Post: 01-23-2002, 02:17 PM
