Results 1 to 10 of 19
Thread: 2005 Lincoln Navigator CAN Bus
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    Hey, I was wondering if anyone here knows of a cheep PC interface for a vehicle with the CAN Bus protocol instead of the OBD-II. (2005 Lincoln Navigator)
    thanks,
    Matthew
    Newbie jyaron's Avatar
    Aug 2004
    Quote Originally Posted by techy101
    thanks,
    Matthew
    CAN is OBD2
    Minneapolis, MN
    according to the person on obddiagnostics it's a completley different protocol. (which would explain why the pinouts on the plug were all different, and it wouldn't even think about communicating with the OBD-II interface. Also as far as my searches have come up, although they may use the same connector, they are completley different protocols.
    I have been digging around the net, and i found this http://www.aeswave.com/products/Prod...p?i=455&tsw=su
    but it's still a bit high priced for my taste. looking for something more in the $100 range (like the product from http://www.obddiagnostics.com/
    Exo
    Exo is offline
    Newbie Exo's Avatar
    Jun 2004
    Leeds - UK
    Nov 2004
    CAN is brilliant, if you can get an interface in theory you can control anything in the car - from the headlights to the windows!
    there are plenty of CAN USB interfaces around.
    Mar 2004
    Metamora, MI
    Techy101,
    CAN is a communications architecture. OBDII is a government regulation. OBDII regulation can be met on CAN vehicles using several different protocols (CAN or other). You are confusing existing scan tools that don't support CAN (yet) with OBDII regulation. So, a newer "OBDII" scan tool - that supports CAN - can connect to a CAN protocol vehicle via the same standard diagnostic connector. The pins are different within the connector that CAN has implemented.
    "Controller Area Network (CAN)
    Is a high-integrity serial data communications bus for real-time applications
    Operates at data rates of up to 1 Megabits per second
    Has excellent error detection and confinement capabilities
    Was originally developed by Bosch for use in cars
    Is now being used in many other industrial automation and control applications
    Is an international standard: ISO 11898" http://www.can.bosch.com/index.html
    Feyaz,
    There is not necessarily any additional support for controlling vehicle features with CAN vs. any other protocol. Support of features is up to the scan tool implementation of how much OEM proprietary attributes are supported and how many different modules (engine usually, transmission sometimes, body control module hardly ever outside of OEM scan tools, air bag module once in a while, other modules only with OEM scan tools typically). This limitation is not a limitation of a protocol but that OEMs are not regulated to provide uniform methodology for accessing this data on the vehicle like some of the primary engine controller attributes are mandated by OBDII regulation.
    Generally speaking CAN vehicles have more discrete modules which is what makes CAN a popular protocol for newer vehicles to support for it's ability to handle more data traffic to more modules with less error. This would make you think that you can control these modules offboard, but not necessarily true.
    Mods - Can you enhance this forum's sticky for CAN to reduce amount of common posts asking same questions?.
    Variable Bitrate nottastocker's Avatar
    Jun 2003
    Shenandoah, VA
    Question
    thanks,
    Matthew
    so lemme get this straight... you went out and bought a brand-spankin-new luxury suv, and you're worried about the cost of an interface adapter?
    Minneapolis, MN
    DavidL: Thank you for all the info. It helps to clear stuff up a lot.
    nottastocker: I WISH . There is no way on this earth that i could ever afford a Navigator. It's for a friend. (I tried to convince him to give it to me, but his terms were a bit steep for me)
    Aug 2004
    that is incorrect
    PHY layer is different
    upper layer conforms to J1979 (OBD2) via ISO15765
    Oct 2006
    Las Vegas
    Arise!! My old thread......muahahahahahah
    Does anyone know where I can find a copy of ISO 11519 (low speed CAN), ISO 11898 (High speed CAN) without spending a fortune?
    An up to date (4/30/02) SAE J1979 would be nice too, but I can live without...
    It's been a while...
  1. Sony BUS Aux-in workaround
    By BigfootsMonk in forum Newbie
    Last Post: 03-23-2010, 04:05 PM
  2. Solved: USB bus stays powered after shutdown
    By S4Per in forum Power Supplies
    Last Post: 05-28-2007, 09:09 PM
  3. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 11:54 AM
  4. Rikaline 6010 & Delmore street atlas USA 2005
    By raymondaecom in forum GPS
    Last Post: 11-30-2004, 01:32 PM
  5. Via Epia M PCI Bus Speed?
    By Nico3k in forum General Hardware Discussion
    Last Post: 09-23-2004, 06:05 PM
