It's usually about halfway between the air filter and the throttle body, after the MAF sensor. The biggest problems using that sensor is that it will fluctuate with RPM, uses moving (possibility pre-heated) air, and you have no way of telling how accurate it is vs the *C or *f scale. The car doesnt care if the air is 20* or 50* it just reactes the the voltage and compares it downstream with the O2 data to determine the a/f ratioOriginally Posted by Skipjacks
LinkBack URL
About LinkBacks
