Results 11 to 20 of 28
Thread: speedometer calibration??
  1. #11
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by n8scstm
    Thanks, thats cool. But I need more than 28%. I had 30" tires. Now I have 40" tires. But I guess after I gear it, then it would work. But I'm not sure if I wanna spend $1000 to gear the rear end at this point.
    Use two of those
  2. #12
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    LOL. If that even works I really can't justify spending $200 when I could get the programmer for $400. Come one guys, I was trying to be cheap. Guess I chose the wrong hobby.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  3. #13
    Jul 2004
    Berkeley, CA
    http://www.autotransinc.com/Recal.htm
    http://www.drivetrain.com/autotransc...alibrator.html
  4. #14
    Mar 2004
    Metamora, MI
    Quote Originally Posted by lawrence
    I have work on mitsubishi /chysler and on certin cars pinon factor can be set with the DRB3 , but only to the tire sizes set at the time of manufacture.
    i do not know about other car lines as they may have something the same.
    but i dont think that any scaner will do this, as the name implies they scan but do not reflash. to reflash a engine control unit needs a programer. programers are done by the manufacter , and to reflash without epa approval is a emmision violation. no maker of a "scaner" want that kind of heat from the epa, without a "off road use only" waiver.
    The DRBIII software does some calculation based on tire sizes that were preconfigured so that the proper pinion factor is implemented with the most common tire configurations. The vehicle needs a mathematical figure to correctly display speed based on calculated speed. The DRBIII software does this calculation for the user to speed up routine service processes.
    Changing the pinion factor does not require a reflash of the ECU. It is a setting that gets updated on the ECU's current firmware. The firmware is certified by the OEM to comply with the EPA regulations. The issue of a scan tool provider supporting pinion factor is one of work and not regulation. Each OEM does it differently (on each vehicle line) so the effort of those permutations is significant. And the availability of vehicles to validate that it works is another level of effort and cost.
  5. #15
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Use this. Use Photoshop to adjust the location of the markings. Print out on photo paper. Drymount to your speedo. Done
    Want to:
  6. #16
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    I think you can get your speedo readings from your GPS and show them on screen instead of using your speedo. I know Tom Tom shows your speed on a pda setup
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
  7. #17
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Damn you bugbyte you beat me too it! The best idea by far - cost you penies and you can put some nicer dails in your whole dash!
  8. #18
    Mar 2004
    Bristol
    Quote Originally Posted by old_lou
    Was using a TomTom today and it was showing my speed about 5mph higher than the clock in the rented Passat i was driving and also does the same in the Merc. Readings where very constant too so it seemed pretty accuate - very strange. Maybe most cars underread a bit - would explain why the speedo in my mums fiesta 1.1 used to do 110 when i was leaning to drive in it
  9. #19
    Mar 2004
    Metamora, MI
    Quote Originally Posted by Bugbyte
    Problem is you will have to stretch the dial to the right or left from zero for it to be accurate
  10. #20
    Jul 2004
    Berkeley, CA
    Ninja Monkey's D3 also has a huge speedo. iG and Routis have tiny speedos.
  1. GPS Speedometer?
    By aphesis in forum GPS
    Last Post: 07-14-2008, 08:11 AM
  2. Replies: 11
    Last Post: 11-15-2004, 08:30 AM
  3. Is my touchpanel warped? calibration is way skewed
    By Grayscale in forum General Hardware Discussion
    Last Post: 09-13-2004, 05:48 PM
  4. Endless calibration.
    By Blanqui in forum Input Devices
    Last Post: 09-11-2004, 12:38 PM
  5. Lilliput 4-point and 25-point calibration?
    By chris in nh in forum LCD/Display
    Last Post: 06-20-2004, 01:16 AM
